Based on my plan for a moving gantry design 3' x 2' router to cut wood/acrylic. I have (3) x Compumotor S57-102-M0 complete with DRC E57 C153/421 encoder. Are these motors ok for my general requirements. Should I use the encoders or save for later. Is a parallel port driver card suitable for this build, what should I look out for, or can someone give me a fingerpoint to a suitable make/model. Appreciate any help or guidance |
| Depends on the machine.... These Servo's will generate 125oz/in of torque so they are not that powerful. You'll probably use some kind of belt/gear reduction system. Most folks do with steppers since they operate at high speeds. Here are the specs on these...http://www.compumotor.com/catalog/c67_74.pdf I'd use the encoders since it'll eliminate missed steps. Even with the servo and encoders you still need drivers for the servos. Like one of these for each servo: http://www.geckodrive.com/product.aspx?c=2&i=14474 A standard BOB (Break out Board) will be used to connect to the PC via a parallel cable and then connect the BOB to each of the drivers that then connect to the servos. You will also need a power supply. |
A bit more research and a build thread are ahead of me. |
| If you want to use those stepper motors, I have two M57-102 modular drivers that match perfectly. Line voltage in, add step and direction signals ( encoders would connect to an indexer like the parker 2100 or a Mesa FPGA etc.) Motor drive out! Too bad you are across such a deep body of water ;-) Matching hardware kept from providing joy by distance...... CalG |
I'm pretty much settled on a gecko 540 and (3) 380oz steppers from a couple of places in USA, the thought of having to pay customs and vat :-( if only there was a way .... These steppers may end up on ebay I reckon someone may have a use for them, i'll probably keep the encoders though for future use. cheers |
| Need Help!- 1 Driver 2 Stepper Motors, is it possible will it work? | guy2b1 | DIY-CNC Router Table Machines | 30 | 10-01-2009 05:59 AM |
| Need Help!- Stand alone encoder controlled stepper driver | JWWalthall | Open Source Controller Boards | 4 | 10-10-2008 12:28 PM |
| Need Help!- Help selecting a good driver for my stepper motors | rapture | Stepper Motors and Drives | 7 | 02-13-2008 06:52 PM |
| Wanted DIY stepper driver circuit for 6 wire stepper motors | Colin300 | Australia, New Zealand Club house | 5 | 09-20-2007 09:20 PM |
| Encoder for stepper motor driver | takeda | Stepper Motors and Drives | 1 | 09-15-2007 11:21 AM |
