Old 01-28-2010, 04:37 PM
Propaganda's Avatar
Propaganda is on a distinguished road
So, I bought a vacuum pump and took it apart. PIC
I bought a vacuum pump for my DIY CNC's vacuum clamping assembly. When I manually turn the unit it sounds like metal touching metal. I opened it up and everything looks really good, just a little gunk.
Since it's oilless and the seals have no damage I am just going to clean that one spot of gunk and reassemble the pump without adding lubrication. That's right. right? No lubrication of any kind?
-Thanks!
"The whole world must learn of our peaceful ways... by force!" - Bender Bending Rodríguez
Old 01-28-2010, 05:40 PM
Propaganda's Avatar
Ok, silly me. The noise are just the metal flaps resonating in the air flow. IDK their technical name.
Old 01-28-2010, 11:11 PM
tpworks's Avatar
tpworks is on a distinguished road
Reed valves
...He who makes no mistakes makes nothing! ...
Tom
Old 01-28-2010, 11:23 PM
eloid is on a distinguished road
before you put it to gether take more pictures, it alway interesting
to see the guts...
Old 01-29-2010, 02:09 AM
Propaganda's Avatar
Reed vavles! , thanks.
Per request here are about a bazillion pictures.
I picked this baby up on FleeBay for $65+$20(shipping). Then I bought the rest of the vacuum pump gear at http://www.veneersupplies.com. My project is a shadow of http://www.joewoodworker.com/veneering/EVS/concept.htm
Enjoy.
pump
pump
pump
pump
pump
pump
pump
pump
pump
pump
pump
pump
pump
pump
pump
pump
pump
pump
pump
That's it. The pump is working great so I felt no need to strip it down further.
*edit*
Come think about it I think I should rethreadlock bolts.
Vacuum table and vacuum pump garagefela DIY-CNC Router Table Machines 19 01-25-2012 10:30 AM
Vacuum Pump ranchak Moldmaking 20 10-26-2009 12:13 PM
OK, I've got my vacuum pump. Now what do I do with it? DougO Work Fixtures and Hold-Down Solutions 0 07-09-2008 02:35 AM
Need Help!- Vacuum Pump jfcamilo DIY-CNC Router Table Machines 5 04-29-2008 03:45 PM
Where to get a vacuum pump whiteriver DIY-CNC Router Table Machines 2 05-11-2004 10:47 AM
