Greetings all. Long time listener, first time caller... I have saved a small CNC router from the scrap heap as it was sent down from a closed sister company and not a sole here knew what to do with it. Being the generous sole that I am, I offered to give it a good home and put it all back together. About the only info that I have on it can seen in the pictures. My questions are; 1) Is it a commercial machine? 2) Are these stepper motors overkill for such a small machine (15"x9"x4")? 3) AA has the control software on their site which I downloaded and ran a few lines of code from a dxf. Seems okay but has little control. Could I run a controller like this with something like Mach3? 4) How would I find a post processor for a machine as simple as this? Thanks for your time, Brog I'm a ME with years of Autocad and Solidworks experience but a newbie to CNC. I'm dabbling in Mastercam X on the side which I would like to start using to produce the 3D code for this machine. |
| Wow! What a find... "Steppers Too Big?"... Unless they are NEMA-42, It's not really possible. No idea if it's commercial or not but I'm sure that with a few Geckos and Mach or EMC you could get it running well as long as it's straight and slides. The controller looks kind of intimidating.. If the controller will take the standard Dir/Step signals than it's a breeze and no Geckos required. Do you have or can you find any info on the controller? Mil
__________________ ...time spent working on hobbies is not deducted from your lifespan... |
| I agree what a find, it looks like a PCB router we have a work. it looks like the Anahiem website has the info and software you need. http://www.anaheimautomation.com |
| Thanks.. " I agree what a find, it looks like a PCB router we have a work. " That's funny one of my first projects will most likely be a PCB and an acrylic enclosure for the Arduino that my friend is getting me hooked on. I've loaded the software got it all setup. The software is pretty basic..allows for a .dxf import, jogging. I imported a .nc file from Mastercam but it had several codes that it did not recognize so of course it did not run. I did however import a simple .dxf file and was able to cut a piece of mdf with it. (Simple square, nothing fancy) My next step is to either try to work with MasterCam and the post processor to get it in the format that the AA software wants.(There is a huge learning curve on doing this it seems) or download and start messing with something like Mach 3 which I hope will be a bit quicker to figure out... What are your thoughts? |
| That software appears to be a modified version of Flashcut. http://www.flashcutcnc.com/popup/flashcutScreen.php I don't believe you'll be able to control that with Mach3 unless you bypass it and go directly to the drives, if you can.
| GER21- Thanks for that input about it being similar to flashcut. Mastercam has a flashcut machine definition and post on their site which I downloaded and works. Zephyr9900 Couldn't get the page to come up...It did have a small cover plate that said iso-mech-tech I believe. |
| saleCNC laser engraving machine and CNC woodworking machine | zhangrui1588 | Laser Engraving & Cutting Machines | 3 | 05-08-2011 03:54 PM |
| Need Help!- Hardinge CBN Turning Machine with GE Fanuc Machine Model CS- 51, S.No. CL – 622 -BSP | M.RISHIKESH | Hardinge Lathes | 1 | 11-20-2009 06:03 PM |
| sell CNC Woodworking Machine,CNC Advertising Machine | zhangrui1588 | Product Announcements & Manufacturer News | 0 | 05-30-2008 08:43 AM |
| Deep Groove Taig machine would it be a good starter machine | Fritzie15 | Taig Mills & Lathes | 0 | 09-20-2007 09:37 PM |
