This may seem like a silly question but when driving the Y with two steppers, one on each side, do you need another driver for that fourth motor or can you chain the two together? Naturally if you use one driver for both motors one would have to run in the opposite direction. How is this usually done? |
| driving two motors with one driver is not a good idea. You should use one driver for each motor. The inputs to the drivers may be connected together, and the stepper wires reversed on one motor will give it opposite direction. Or you can wire both steppers the same way, and deliver matching opposite inputs to the drivers through software (there should be an option in your cnc software that does this)
__________________ ___________________________ www.carveit.ca |
The proper way to do this is to have an individual driver for each motor and use the settings in Mach3 Ports and Pins menu to slave the A axis (fourth axis) to your Y axis and to reverse the A axis motor. The drivers can be on one circuit board layout or a separate module like the Geckos. [On my machine I reversed the phase B coil wires on my A axis motor so that this motor setting in Mach3 is the same as the X axis.] If you just parallel the input wires to the two drivers the signal level may be too low to properly operate either drive input. It depends on the driver input circuit design. If you parallel two motors on one driver output it is very likely to damage the driver output device. CarveOne
__________________ CarveOne Resistance is not futile. It is voltage divided by current (R=V/I). |
| Hello, I bought dual drive from Granite Device http://granitedevices.fi/index.php?q=products for my plasma, 2 ea dc servo motor using 1 ea drive. I am building now. So total using only 2 ea drive. My purpose here is just for simplicity but I need power too. I use 4 ea 1125 oz in kelling motor on all axis. |
| No, normally the driver will limit current to the same amount, but with 2 motors connected they will only get half the required current each, so they won't work very well. Also the motors can produce different back-emf as they operate which can confuse the driver and cause weird operation and possibly driver damage. |
#10
Unless you know for sure that the driver design you have is able to work with paralleled motor wiring it is not a good idea to just wire them and see what happens. Unless you are willing to lose an otherwise good driver board. CarveOne
| Driving me a little NUTZZZ! | Cellar Dweller | Mastercam | 5 | 10-20-2009 08:44 PM |
| Driving the Knee? What do you think? and Why? | Ron111 | Knee Vertical Mills | 65 | 07-16-2008 10:51 PM |
| Driving one axis with two stepper motors? | stevesplanes | Linear and Rotary Motion | 15 | 05-09-2007 03:03 PM |
| Driving Xylotex with PDA | Sanghera | Xylotex | 0 | 04-28-2007 10:32 PM |
| Driving Parrallel Port | JOE65 | Mastercam | 0 | 03-22-2004 11:16 AM |
