OK here goes. I have and idea for a CNC router using a 2-1/2 hp router. Cutting area X=32" Y=20" Z=6". I have 2 ea hardened to RC60 1-1/4" rods with thompson linear ball bearings for the X axis I plan to use the rods unsupported in the middle and anchored on the ends. I plan to use 3/4" hardened steel rods for the Y axis with Thompson linear ball bearings. I will use 1/2" hardened steel rods for the Z axis with Thompson linear bearings. I have a good source for new Thompson bearings. I was going to use 1/2" aluminum plate for the movable gantry sides. Plan on using 5/8" ball screws for all drives. I cannot decide on stepper motors, 269ozin or 640ozin both with Gecko drives. Please let me know what you think. My main concern is will the X axis be rigid enough W/O support in the middle. I plan to put 4 bearings on the gantry (2 per side) on a 12" wide gantry. |
| To get a 32" cutting area, you'll probably need at least 44" of unsupported length. This will most likely have some deflection. But, you may be able to eliminate most of it by double clamping the ends a few inches apart. You'd probably need 50" shafts or longer, though. If you're spending the money on Gecko's, go with the bigger motors.
| Thanks for the info. I will use the 640 steppers from Homeshop CNC. Which Gecko drive to go with? Is there a big advantage to the 210 over the 201 for a router of this size. I will use .750" lead screws with a .200 lead on the X & Y. What will the 210 get me?? |
| Newbie - To build or not to build Router/Plasma Table | dfranks | CNC Plasma and Waterjet Machines | 10 | 04-07-2011 11:16 PM |
| Complete Newbie seeking for help. - Clisby mini machines. | some8 | Mini Lathe | 11 | 03-13-2006 08:23 AM |
| Newbie questions. Planning a new machine. | space_case | DIY-CNC Router Table Machines | 17 | 08-02-2005 03:50 PM |
| Autocad user has newbie SW/CNC questions | cadesignr | Solidworks | 7 | 02-11-2005 01:19 PM |
| Total Newbie on Taig CNC Mill!! | vwgo | Taig Mills & Lathes | 2 | 10-17-2004 07:40 PM |
