So I'm building my router table and a thought suddenly occurred to me. I'm using 2 motors for my x axis, which run on a chain/sprocket system. Sounds like it should run fine, except... When the machine isn't running, if I bump one side its going to rack it all out of wack. Its a similar configuration to this one: http://buildyourcnc.com/blackToe4x8.aspx Am I just being worried for nothing? |
with the proxy switches if you use mach there is an auto squaring setup, which will align your gantry to the switches so once they are square ( the switches and the off sets in mach to align the gantry) auto squaring will be quite simple and automatic I use the switches and they work great, and are easy to set up and are relatively cheap... good luck, cncsigns |
| Thanks guys! After doing a bunch of research on the subject, I found another guy that solved the problem by using a system of cables and pulleys. Seeing as how I'm strong in mechanical and electrical stuff and pretty much suck with computers, it sounds like a better solution for me. Thanks all! P.S. At some point I'll be building a second generation machine (seems like most folks on here do) and I'll definitely keep the software alignment in mind. |
| You could also use pulleys on the ends of the screws with a 3/4 wide belt running between them with an didler in the middle to eliminate slack. This'll keep them in alignment. I just use the switches to align the gantry. I'f I've really tweaked it I turn off the switches and software stops and let the gantry square up against the stops. You'll get some noise but if you don't crash the gantry into them it doesn't hurt and gets every thing nice a square. |
| Linistepper (unipolar driver) with aligned transistors! Eagle files | patriciooholegu | Open Source Controller Boards | 2 | 08-28-2009 10:38 AM |
| Just IN- Provide controllers,drives,servo motors,stepper motors,electronic parts from China | Ling | Product Announcements & Manufacturer News | 2 | 07-12-2009 04:10 AM |
| How to bore aligned holes? | flathead | General Metalwork Discussion | 4 | 05-08-2009 10:00 AM |
| miss-aligned machine axes | adamchapman | Mach Software (ArtSoft software) | 1 | 07-13-2008 03:02 PM |
| stepper motors or servo motors? | jprobst | Torchmate | 3 | 07-13-2007 05:37 PM |
