Old 01-25-2010, 07:54 PM
nate24168 is on a distinguished road
Please point me in direction of suppliers, and plans for a modest router that can do
Please point me in direction of suppliers parts, and plans for a modest router that can do aluminum, and mild steel. I want to have a do it myself build, and have good components at a fair price. I have seen a few plans that give you prints to build one that looks KA but you need to have custom cut parts, or bent. I just want to purchase parts I can not fab up with a saw, plasma cutter, welder, and basic tools.I tend to follow the spend once method from experience but have seen a vast price range for similar components.
I am interested in a 2'x4' or 4'x4' set up. I will enjoy links, and personal advice. Also please tell me what to stay away from.
Thank you for you time.
Old 01-26-2010, 07:01 AM
Tweakie's Avatar
Tweakie is on a distinguished road
Because everything in life is a compromise Modest Routers, which may not have the dynamic rigidity of a Milling Machine, use high speed spindles which are not really suitable for cutting mild steel parts - they basically excel at cutting wood and plastic parts.
I built my own CNC Router but I also have a benchtop CNC milling machine and between the two can make most of the small parts I require - however, neither machine is good at doing the other's job.
If you have the time, take a look at my website http://www.cooperman.talktalk.net/
Tweakie.
CNC is only limited by our imagination.
Old 01-26-2010, 08:06 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
"spend once method"
If you truly want to follow that motto, building a router to cut steel is way off.
You need a milling machine.
www.integratedmechanical.ca
Old 01-27-2010, 06:08 AM
CarveOne is on a distinguished road
If precision steel machining is your DIY goal then you should buy a used knee mill and do a CNC conversion on it. It will be the correct machine for your aluminum and steel cutting needs.
A DIY wood router is totally the wrong machine to build for this. Though some of these can do a decent job on aluminum, they usually have a mini-mill spindle on them, not a wood router.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Newbie- Please point me in the right direction... jnymarkp Want To Buy...Need help! 4 12-31-2009 03:17 PM
Please point me in the right direction (Omniturn) Zebu Fellenz Post Processors for MC 1 03-02-2009 10:14 AM
Need Help!- Point me in the right direction Flyin04 Joes CNC Model 2006 6 08-29-2008 10:01 PM
Some modest C2 mods. Claven2 Mini Lathe 50 06-15-2008 07:45 AM
Where to start ? point me in the right direction... cruizer67 DIY-CNC Router Table Machines 2 09-12-2005 08:44 PM
