Old 01-25-2010, 06:23 PM
jnnewton is on a distinguished road
Router for metal
So I started building a router a couple of days ago, so far:
1. I have a welded steel frame, fairly flat and straight for the size
2. I have a semi-constructed carriage
Problem: I don't know how to align everything. i have everything clamped together right now (as you can see by the clamps hanging off), aside from the sides, which are bolted to the bearing blocks, and one rail that is screwed 2x to the frame. Ideas on how to get everything squared up? pictures attached (probably bad quality, camera phone)
ID:	98479   Click image for larger version
ID:	98480   Click image for larger version
ID:	98481   Click image for larger version
ID:	98483   Click image for larger version
Old 01-25-2010, 06:33 PM
Oh, and I want to be able to get down to around 150-200rpm for face milling aluminum / steel, but i am not sure how to do this on the cheap, I am not extremely interested in the 10krpm spindles for wood (or i would just use a router) but still want to do it on the cheap (100-150 bucks for the spindle / motor, kind of like what a router would cost)
Old 01-26-2010, 12:29 AM
arizonavideo's Avatar
arizonavideo is on a distinguished road
I take it you have not face milled with a 3" cutter in AL before?
Your machine looks fairly strong for a router table but swinging large tools may prove to be a problem.
Many have used a X2 spindle with good performance.
Old 01-26-2010, 06:07 AM
I have a single indexable insert face milling tool, a older style, I run it at 150 on my mill, I take it you have not used the same style tool, and the speed seems off? No matter, I would like an r8 spindle as I have collets/ tooling for this size. As for the stiffness, I am only part way there, but need to get this thing squared up. Any links to a procedure of some sort?
Old 01-26-2010, 07:44 AM
EBC's Avatar
EBC EBC is offline
EBC is on a distinguished road
Question
where did you get the sides for the gantry?
servicio de fresadora cnc
Old 01-26-2010, 07:54 AM
I scavanged them from an old machine (robotic assembly machine), it was one plate (1/2"), then painfully cut with a recip, bolted them together and finished on the manual mill. the bottoms and back are perfectly square, but the height / front edges are not perfect by anyone's standard.
Old 01-26-2010, 08:32 AM
jsheerin's Avatar
jsheerin is on a distinguished road
Try this for a head:
http://www.cnczone.com/forums/showth...ead#post693759
You can buy the complete head with motor and speed control from Little Machine shop for around $300 I think.
For squaring, one way would be to go with a machinist's level and machinists square. Square the frame and then level all the pieces in both planes. It's a pain in the rear, but it works. Although with your rails on the outside of your frame, that will be a little tougher... If your frame is level across the top in both planes, the sides are at the same angle to the top on both sides and the frame is the same width along its entire length, you could just measure down from the top of the frame to locate your rails. You can get cheap machinist's levels from Grizzly and similar places, or bigger more expensive ones from companies like Starret for significantly more money. I think I bought my squares from MSC and they were Spi's on sale for reasonable prices. Basically the same deal there - the bigger and more accurate the square, the more it costs.
Old 01-26-2010, 08:55 AM
Sold!!!
I have a machinists level, and I believe the top of the table is fairly flat, but it's just the frame, I was hoping to do some shimming for the rails, however, they are very far apart, so although leveling across the table is unnecessary, parallelism is of extreme importance for lowering friction and flex in the machine. I feel as though I could make each side of the frame extremely flat, and check / shim one rail to it, but that doesn't mean the two sides are parallel, or even at right angles to the top. not that they need to be, but twist and parallelism could be a problem that could be measured if i was able to prove the top was square...aha, that's what the squares are for!...ok, off to get some machinist squares. And I see you even mentioned that.
Old 01-26-2010, 09:05 AM
jsheerin's Avatar
The other thing you could do is once you get the rails parallel to each other in the vertical plane (so they're both parallel to the top of the frame for example), then you could mount the linear bearings on one side and some type of roller bearing on the other side of the gantry to ride on top of the rail. Then mount a dial test indicator and run the gantry along to see if the rails are parallel in the horizontal plane. Or you could just mount the bearings and see if you have binding, but the dti would tell you were the binding if you had some.
Old 01-26-2010, 10:22 AM
Phife is on a distinguished road
I used a combination of a machinist level, machinist square and a regular tape measure.
Like everyone else said, make sure everything is level and fairly square.
Then use the tape measure to measure the distance from one corner to the opposite side corner (diagonally) and the repeat with the other corner to corner. They should equal each other, if they dont then its not square.
I use a large pipe clamp to pull on the longer side until the 2 diagonal measurements were equal.
Hope that made sense..
  #11   Ban this user!
Old 01-26-2010, 11:03 AM
All of it except the pipe clamp part, as this thing is welded, there is no way a pipe clamp is going to move it, bend it, or otherwise squeeze it. How Equal are we talking here, within 1/8? 1/16?...
It does seem that i am going to have to weld another cross member, as the x-axis tubes seem to be slightly bowed inward toward the middles.
Alright, i have ordered the spindle housing assembly and the belt conversion from a mini-mill. Off to make it all square and flat.
  #12   Ban this user!
Old 01-26-2010, 10:54 PM
I have mine nearly exactly the same. I'd say there is no more than 1/32 difference in the cross measurements anywhere on my frame.
If yours is off by more than 1/8 I'd try to look into ways to improve it.
Substitute MDF for metal on a DIY router? posix DIY-CNC Router Table Machines 16 09-18-2009 03:26 PM
Build cnc router without linear ball bearings ?? Flat metal on flat metal with lube ? vroemm Linear and Rotary Motion 7 08-16-2007 12:26 PM
2nd Router. All metal construction. paulC CNC Wood Router Project Log 35 01-22-2007 01:20 PM
2nd CNC Router Build (metal) Sanghera DIY-CNC Router Table Machines 56 05-23-2006 10:46 PM
Wood and metal router kenlambert DIY-CNC Router Table Machines 2 10-26-2004 09:36 PM
