Old 04-10-2005, 05:11 PM
samsagaz is on a distinguished road
wich Machine can i buid to mill PCBs?
hey guys, i readed a lot of threads but cant find an machine to drill PCBs, dont know if i need to follow an tutorial to create an for woodworking or metalworking
can someone tellme where to start?
i just want to create holes in PCBs.
thanks
Old 04-10-2005, 05:56 PM
JRoque is on a distinguished road
Que tal?. I started with the same question a few months back. I wanted to build a small machine, maybe 12"x12". I ended up building a much larger one that not only drills PCBs but also mills them. I do all of my prototypes inhouse now.
For this application, you'll need zero or close to zero backlash on the axes. This is important if you need accuracy and most do. Next, you will need a good router/spindle. I started with a Precise brand router and had good results. I switched to another popular wood router and the PBCs looked like they were being chewed instead of milled. My best results so far have been while using my own spindle. The important spec with the spindle, perhaps next to speed, is minimal runout.
Read the forums around here, go to eBay or similar available to you and start the buildup. Check out the 8020 ads here and build the frame out of that. Folks on this site are great and will be quick to lend you a hand and suggest ways out of trouble.
Regards,
JR
Old 04-10-2005, 06:21 PM
JRoque, if i build the jgro Wood Router it will work for mill the PCBs?
or you know any proyect that will fit?
Old 04-10-2005, 06:35 PM
That will likely work. Unless you're in a hurry, you should spend some time reading this site and learning about your different options. Like I said, I was initially looking for the same thing you are but ended up with something very different which does a lot more work and it's a better fit for me.
JR
Old 04-10-2005, 06:46 PM
i dont understand very well the software stage, i can use any soft to drill it?
first i want to order the steppers from USA... here cant get an good one, here i need to pay likr 55 U$S fot an stepper motor with 200 steps 5V and 1.4A, i think that its not enough, i want more ampers and maybe more volts too, so i was thinking abt order it in USA. and maybe buy the Stepper Driver too.
what you will recomend me?
if u already spend a few days reading maybe can help me a bit my main problem is my damn english
i try to read everything but understand like mmm 30-40%
Old 04-10-2005, 06:49 PM
would be great if i can build an machine that cut wood and pcbs and drill it too.
metal stuff i think that will be more expensive.
have u any pic of your machine?
i want it a little bigger (to route wood too) like 30"x20"
but i was thinking that maybe the best choice is build 2 machines, one small for pcbs and another for the woodworking
Old 04-10-2005, 09:32 PM
Well, if there's anything I can do for you in terms of translating, let me know. I'm not too good with English either but can do Spanish.
Here's my machine log. It hasn't been updated in a while but you can see how I started with a couple of 2x4 for a frame and a few clamps.
Shoot me a private message and we can get going. Unless anyone else can benefit from the foreign language discussion here? Let's see: alguien mas interesado en discutir el como montar una de estas maquinas para hacer circuitos impresos?
Cheers,
JR
Old 04-10-2005, 10:07 PM
you speak spanish?! i speak spanish!!! btw.. ill see your machine log
Old 04-10-2005, 10:18 PM
WOW!!! after read your post abt your machine im amazed!!! you machine is really good dude! i like it!!!
Old 04-11-2005, 08:28 AM
Why thank you, sam. BTW, don't look too much at the voltage rating of your steppers. Yes, it matters but what you're looking for is reasonable torque or holding force. My steppers are rated at ~2.6v and they have around 180oz holding. With a .2" per turn screw they have enough power to cut just about anything I've thrown at it.
So..... no mires mucho el voltaje de los motores. Con >150oz de fuerza y tornillos de 5 a 1 es suficiente, especialmente para la aplicacion que intentas. Por otra parte, puedes construir la maquina que indicas arriba pero realmente es mas economico y hasta resulta mejor que utilices lo que tienes a mano. Por eso sugeria que leyeras este sitio para que tomaras tus propias decisiones. Fijate que rara vez hay dos maquinas identicas aqui. Empieza con la armazon de aluminio de la compaņia 8020. Luego te busco mas links de otra piezas.
JR
  #11   Ban this user!
Old 04-11-2005, 09:18 AM
the biggest torque that i found in my country are 6000 (g*cm)
ill still reading,
  #12   Ban this user!
Old 05-22-2005, 05:12 PM
campaX is on a distinguished road
I'm really intrested in the same project (milling and drilling PCB)!.
Estoy realmente interesado en el mismo proyecto.
I bought some motors in eBay and, and i'm waiting to win an auction of some linear pillow blocks bearings.
I'm collecting parts enough to start my own design.
I already built a router like two years ago, but it had too much backlash, and the motors were too small. you can see it here.
I'm thinking in using a dremel as the router/spindle for PCB milling... what do you think? JRoque
Cuentame como va tu proyecto samsagaz? si quieres escribeme en espaņol.
Mario.
Bridgeport mill newbie question... GalaticDan Bridgeport and Hardinge Mills 3 06-06-2005 02:02 AM
Manix CNC small mill machine, US importer? wisp General Metal Working Machines 10 05-02-2005 01:16 PM
Mill Drilling Machine Conversion.. Help Please zorgzorgzorg General Metal Working Machines 3 04-13-2005 07:49 PM
Dont know where to start... Mill Electronic PCBs samsagaz General Metalwork Discussion 7 04-11-2005 02:00 PM
FeatureCAM Expands Product Offering with Machine Simulation CNCadmin Product Announcements & Manufacturer News 0 01-21-2005 06:58 PM
