Old 01-20-2010, 09:06 PM
eloid is on a distinguished road
need bits for cnc carving (beeding bit)
looking to source carving bits, InParticular I need a beading bit
that looks like 60deg v grove bit but has curved raduis for making carving ie beads.. I want to make a string of tight spaced pearls in a crown moulding
and the standaard v shap bit will hit the adjacent beed... I need a curved
beaded profile with a sharp point like a v shaped bit?
Anyone know where to source this bit and other just for carving
Old 01-20-2010, 09:50 PM
ger21's Avatar
Like these?
http://www.eagleamerica.com/product/...groove_forming
Old 01-22-2010, 12:50 PM
Originally Posted by ger21 View Post
Like these?
yes , just like them!!! ... but has anyone seen bits that have a long
shaft .... for complex carvings that require long lengths
ie planing on carving columns and complex curved crown mouldings / arch tops for furniture with carving details. You can quick bottom out your router
on your work pc if the item can not placed flat.
Is there anyone that carries longer bit for cnc for carving? i seen the extension for 1/2 bit from eagle america nothing for smaller bits ie 1/4"
has any got theis extention .. does it work well?
thanks ger21
cnc carving bits eloid DIY-CNC Router Table Machines 0 09-25-2009 10:39 AM
Newbie- Soft to Hard Metals what bits to use for Cutting Carving Engraving guy2b1 DIY-CNC Router Table Machines 2 09-23-2009 06:00 PM
Router bits, End mills v bits bogger44 Commercial CNC Wood Routers 3 12-03-2008 12:06 PM
Relief carving small detailed parts - V-carving from greyscale image ALAN2525 General CAM Discussion 16 02-11-2007 05:01 PM
Image Engraving/Carving bits Dman DIY-CNC Router Table Machines 1 04-16-2005 04:41 PM
