| The advantages of CNC is 'in your face' obvious and I had to get this challenge on the way. The design is my own and I welcome advice on the way forward.... So here is my product from research done on the net.....thus far. Tnx to all who posted!!! |
| Heya!, Theres nothing like 'bad ideas' in DIY mate, only 'learning the hard way'.... How far are you with the unit? I would like to look at your design. What software will you be running - battling a bit here..... |
| Update! Completed assembly less the spindle attachment and stepper motors. Looking good so far - cant wait to run! (you'll notice my DIY furnace on the right on the first pic) Looking for a simple,compact spindle design. Does any1 have suggestions? |
| It looks pretty good so far. Once concern I have is the rails. What diameter are they, what kind of accuracy are you hoping to achieve, and what do you plan on milling? Unsupported rails can have some pretty substantial deflection. They may be fine for your purposes, I just thought I'd raise the issue. |
| Hi Jesse B! Tnx for your reply. I'm using dia 16mm rails. Yes I agree on the deflection and I have a sturdier design on hand - however I need to run the unit to cut out foam profiles for lost foam casting. So 1 use would be a cnc wire cutter. However this would not be limited to foam - wood and light metal work's tucked away in my head. I have the X-axis rails pre-tensioned to add to rigidity and plan to do the same on the Y-axis. |
| Captain Chaos (I assume), Hi, Tnx for ur feedback!!!. I am blessed with all kinds of aluminium profiles as I am an Engineer at an aluminium extrusion company!!! So the garage is filled with all sorts of nice shiny ali. The profile I used is 80x80mm - Cool stuff to use as there is provision for adjustment- just loosen , reposition and tighten up!!!! We supply to a company called OCTONORM. They make up exhibition systems but I am sure they could supply profiles to you. They are also situated in Belgium see below... Octanorm Belgium Phone : +32 (0)2 344 98 80 Fax : +32 (0)2 344 98 00 E-mail : info@octanorm.be Postal address : Rue des Alliés 274 1190 Brussels - Belgium |
| Thanks for the info. I found there website and a PDF with the technical specifications of the AL Profiles you are using. This seems interesting material. I will keep an eye on it. CChaos (it is better not to mention "him" ) |
| Need Help!- with a Precix Table Router with Perske router | SignShop Grunt | General CNC (Mill and Lathe) Control Software (NC) | 7 | 09-08-2010 04:08 PM |
| CNC ROUTER KIT instructables router project | spotlight3d | EBAY ADS | 4 | 12-30-2009 04:11 PM |
| Newbie- Does anyone own a EZ Router Machine? Plasma or Router. | sngatlanta | Commercial CNC Wood Routers | 30 | 04-11-2008 10:48 AM |
| Using a router for the 1st time. Need advice of cut speeds, router bits etc. | Apples | DIY-CNC Router Table Machines | 19 | 09-23-2006 03:33 PM |
| Surfcam PP for Isel router / Precix router | IvanTochev | Post Processor Files | 2 | 05-12-2004 12:27 PM |
