My 2.2 kw spindle from Chinese ebay vender has just has a bearing failure after a year of part time use. I'm wondering if anyone has successfully changed these bearings, and can outline proper procedure, and suggest replacement bearing? Thanks! |
| I an beginning to think some of these bearing failures might be related to VFD-induced shaft currents and resulting EDM discharge through the bearings. You guys need to ground your motor shafts with brushes or whatever you've got to the motor body and the VFD. Don't whine about bad or cheap bearings when the problem is grounding the shaft. I would buy these spindles used if sold at the right price. (Anyone here can send PM if interested) |
| Cnc Masters or Any chinese mill spindle bearing upgrades | m8kingit | Knee Vertical Mills | 1 | 10-19-2009 07:04 PM |
| Need Help!- Bearing Failure on SUDA SD1208 | joeyg | Commercial CNC Wood Routers | 0 | 07-02-2009 04:43 PM |
| Bearing failure question | bob1112 | Mechanical Calculations/Engineering Design | 6 | 11-14-2008 06:56 PM |
| Spindle failure | mechanicer | DIY-CNC Router Table Machines | 9 | 10-31-2005 05:11 PM |
| Bearing Failure | Mr.Chips | DIY-CNC Router Table Machines | 5 | 11-15-2003 10:03 AM |
