Old 01-13-2010, 12:38 AM
lunchtrayrider is on a distinguished road
nifty mdf cnc i am building while waiting for parts for the other cnc router
here are some pictures of an idea i had and as a result had to make. really there is no plan, i stare at it, make a part, stare at it, make a part, bolt together. repeat until done.
other main cnc i'm working on http://www.cnczone.com/forums/showth...668#post717668
feel free to ask any questions. hopefully i'll have this done before the weekend.
ID:	97433   Click image for larger version
ID:	97434   Click image for larger version
ID:	97435   Click image for larger version
ID:	97437   Click image for larger version
ID:	97438   Click image for larger version
ID:	97439   Click image for larger version
ID:	97441   Click image for larger version
Old 01-13-2010, 04:11 AM
martkrui's Avatar
martkrui is on a distinguished road
That's a nifty design! Never thought of using the profile that way around
I'm curious how this design will handle axial forces but I love the "simplicity" of the design.
Still planning my own so taking this variant into consideration.
Doesn't the big slot in the side support make it flex or bend under the weight of the gantry ?
Old 01-13-2010, 10:41 AM
yea the ability for flex is pretty bad. this is really an experiment. the slot allows the drive screw to be directly between the bearings so it doesn't twist the bearing carriage. really to solve the flex you can make the side rails bigger. there are some really tight tolerances with the cross over of the x and y drive screws. it will be more obvious as this gets more finished.
Old 07-07-2010, 06:10 AM
guerd87's Avatar
guerd87 is on a distinguished road
Sorry for digging up an old thread, But I like the design and am interested in it. How did the machine end up performing? Any finished pics or plans?
Old 07-07-2010, 10:03 AM
everything worked awesome, except the rails just weren't tall enough so it never got operational. too much flex so the rail carts just wouldn't roll right.
Building an SX1 from parts. flashedarling Benchtop Machines 17 01-09-2009 02:13 PM
Insert weld bead into assembly nifty but does it work? Rich05 Solidworks 4 01-07-2009 04:54 PM
Polyhedral Puzzles and other nifty stuff mxtras WoodWorking 0 05-10-2006 02:52 PM
Building some Brake Parts energyforce Bending, Forging,Extrusion... 15 12-27-2005 03:53 PM
Have collected parts, now need advive on building MrBean DIY-CNC Router Table Machines 2 10-14-2003 03:38 AM
