Old 01-10-2010, 02:38 PM
deerhunter is on a distinguished road
best pc
I am in the proccess of getting all the parts together for 4'x4' build, I have a few unaswered qeustions, what what are the minimum requirements for the pc to run everything ( mach 3 vectric and whatever else I need) . is their a thread out there that addresses all of the basic build issues
Old 01-10-2010, 04:23 PM
Jesse B's Avatar
Jesse B is on a distinguished road
Pretty much any modern PC will have enough power to run control software.
Old 01-10-2010, 07:28 PM
Pplug's Avatar
Pplug is on a distinguished road
I have a couple of dell GX270's I bought from my school district for $1 each. They run mach 3 and techno's interface great. I do all my designing on a custom built quad core q9550 3.8ghz desktop with a nvidia GTX 260 video card.
The computer that runs mach doesn't need to be a workhorse. If you do 3d design work, a faster comp would benefit you.
Old 01-10-2010, 07:30 PM
Jesse B's Avatar
Even if you're doing CAD, you *can* do it on almost any computer; however, if you want it to be efficient and render quickly, you'll need a decent computer.
Do you already have a computer that you're wondering whether it'll work, or are you planning on purchasing a new computer?
Old 01-10-2010, 07:40 PM
ger21's Avatar
You really should have a dedicated computer to run the machine. I use an old Dell GX150 - $20 on Ebay.
You don't want to be doing anything else on the PC while the machine is running.
Vectric's Aspire will run better with the fastest PC you can get. V-Carve Pro can run on anything made in the last 5 years or so.
Old 01-11-2010, 12:12 AM
CNCRim's Avatar
I agree with Ger21, have one computer just for NC, you put punch other program in the same computer than it change the registry and crash the NC part as well.
My 2cent, I think it's better you get computer that is the about the same age as your software, so it is compatible I found Window 7 I have is not except many of my older software so now I have to keep my old computer incase I need for older application. DON"T get rid of your old computer yet, you might need it some day.
Old 01-11-2010, 07:06 AM
Pplug's Avatar
If you use a computer the age of your software, it will probably be really slow. I think better advice would be to buy a new computer and put an older version of windows on it for compatibility with your software. That way you get better speed with compatibility.
To save money I would build your own. It's easier than you think.
Http://www.glenspeymillworks.com *Techno LC4896 - 2.2Kw Water Cooled Spindle | *Moving Table Mill from an Omis 3 CMM, 500Lb granite base, Hitachi router, Mach3
Old 01-11-2010, 08:52 AM
ger21's Avatar
Actually, it'll be as fast as it was designed to be. They don't develop software to run on computers that don't exist yet, they develop them on what's current.
Old 01-11-2010, 09:40 AM
Jesse B's Avatar
Exactly. I can't imagine that any of this software is multi-threaded yet.
Old 01-11-2010, 09:50 AM
ger21's Avatar
Not sure what you mean, but multi threaded software has been around for many years, well before dual core processors were around. I've been using dual processor PC's since the Pentium 166Mhz was the fastest processor around.
  #11   Ban this user!
Old 01-11-2010, 11:15 AM
Pplug's Avatar
Software has always been designed and built ahead of the hardware. Software designers program the for current generation of computers as the minimum requirements for the program they are designing. By the time the software is released the hardware that it was minimally developed for is a generation or two old. If the program is not very demanding, then they lower the requirements. There is one thing software developers count on.... computers are always getting faster with more memory.
Software drives the hardware!
  #12   Ban this user!
Old 01-11-2010, 07:44 PM
CarveOne is on a distinguished road
Not so. It is a collaborative effort between electrical, mechanical, software engineers and management. Feature creep can hold up any part of the project if not rigidly controlled by management.
I have worked on many types of electronic systems development. In every case the hardware has always been ready for production release before the software is ready for production release. The software loads have always outgrown the memory capacity that was allocated by the software developers during engineering specifications development. Software release cannot usually happen until the hardware design is stable and the final software changes are tested on the production ready hardware.
How much software code have you seen running without hardware? I have seen lots of hardware running perfectly well without any software.
Oh well, I guess the flame war has begun Gerry. I just couldn't resist.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
