Hello, I have a CNC machine I built, and I would like to run this warmup program. Someone else made this program for my machine but it was made to run in EMC2 and not Mach. It wont work in Mach3. Basically its a loop that runs the axis's to their limits and then increases the feedrate by 10 and runs again. can someone more experienced in Gcode and Mach help me out so I can get this working in Mach? Here is the code: (Axis Warmup) G20 G91 #<_FEEDRATE> = 10 O100 WHILE [#<_FEEDRATE> LE 100] O110 REPEAT [10] G1 F[#<_FEEDRATE>] X48.7 Y24.7 Z-8 G1 F[#<_FEEDRATE>] Y-24.7 Z8 G1 F[#<_FEEDRATE>] X-48.7 Y24.7 Z-8 G1 F[#<_FEEDRATE>] X48.7 Y-24.7 Z8 G1 F[#<_FEEDRATE>] Y24.7 Z-8 G1 F[#<_FEEDRATE>] X-48.7 Y-24.7 Z8 O110 ENDREPEAT #<_FEEDRATE> = [#<_FEEDRATE> + 10] O100 ENDWHILE M30 Thanks |
| O100(Axis Warmup) G20 G28G91Z0 G28G91Y0X0 #100 = 10 WHILE [#100 LE 100] DO 1 G1 X48.7 Y24.7 Z-8 F#100 Y-24.7 Z8 X-48.7 Y24.7 Z-8 X48.7 Y-24.7 Z8 Y24.7 Z-8 X-48.7 Y-24.7 Z8 #100 = #100 + 10 END 1 M30
__________________ The best way to learn is trial error. Last edited by CNCRim; 01-08-2010 at 02:56 PM. Reason: Program error |
| It doesnt work, it gives me a "Unknown word where unary operation could be" Line 5. It doesnt recognize the line with the WHILE command. Anyone know whats wrong? |
| Mach3 doesn't support "While". As a workaround, you can create an M code with vb code in it to do what you want, but you'd need to re-write it.
I am not versed in Gcode Mcode or VBcode, how hard would it be to program? Someone out there willing to help me out? |
| Does your control suppose macro? I think best way is keep it simple, instead too fancy. It will keep running until you hit RESET. G20 G28G91Z0 G28G91Y0X0 G1 X48.7 Y24.7 Z-8 F20. Y-24.7 Z8 X-48.7 Y24.7 Z-8 X48.7 Y-24.7 Z8 Y24.7 Z-8 X-48.7 Y-24.7 Z8 G28G91Z0 G28G91Y0X0 M99
__________________ The best way to learn is trial error. |
| Try this out.... M98 calls the sub 100 (P100) 10 times (L10) The letter "O" designates the start of sub (O100) Locate your subs after your program end (M30) M99 Returns the call from the sub **************************************** G20 G28G91Z0 G28G91Y0X0 #100 = 10 M98 P100 L10 M30 O100(Axis Warmup) G1 X48.7 Y24.7 Z-8 F#100 Y-24.7 Z8 X-48.7 Y24.7 Z-8 X48.7 Y-24.7 Z8 Y24.7 Z-8 X-48.7 Y-24.7 Z8 #100 = [#100 + 10] M99 |
| Mach3 Compatible Axis Warmup Program | Phife | Mach Software (ArtSoft software) | 1 | 01-15-2010 09:39 PM |
| What program builds 3D Model from GCode? | cjjonesarmory | General CAM Discussion | 2 | 07-28-2009 02:33 PM |
| Need Help!- SPINDLE WARMUP | CNC_BOB | OKK | 4 | 05-01-2009 03:32 PM |
| VF 6 Trying to get to warmup settings | SpringKing | Haas Mills | 7 | 09-28-2006 09:39 AM |
| cheap bitmap to gcode program | balsaman | DIY-CNC Router Table Machines | 29 | 07-28-2003 01:04 PM |
