Hi, I am now on my 4th design for a motor coupling, but I think this last coupling I've made is very simple to make and could be made with just a drill press. If using a drill press I would recommend printing out a cad drawing to dot punch for the drill holes. You will see from the uploaded photo's I've tapped four holes for button head cap screws but these could also be through holes using nuts and bolts. The material I used for the center band was a food preparation mat it's about 1mm thick. This coupling gives good stiffness ( this depends on the band material ) and a lot of angular and concentric misalignment. Kind regards Dale |
| Hi, back lash is zero, but maybe a little twisting action if there was very high cutting loads. I would guess no more than a Lovejoy type coupling using nylon spider. I forgot to mention in my first post the heat was to make the plastic more pliable and is not to melt the plastic into shape, A candle would work just as well. Dale |
| It appears to resemble an early style automotive Rag coupler used on the steering box? In fact using the later material now used on Rag couplers, may prove to be less flex prone? Al.
| Hi, I haven't used the coupling when cutting yet, just trials moving my large gantry (50kg / 110pounds) I ran a repeatability prog and run 50 passes rapid moves @ 15000mm/m or 590in/m and repeated fine with no loses in position. I had two Lovejoy type coupling with nylon spider centers on previous to fitting my new band coupling, but they did not give enough run out play, as my lead screw end is running out .002"/.004" I could see this was putting a load on my lead screw and motor bearings. I've just tried twisting the coupling by hand so far and it does resist twisting action well, but this will all depend on the band material used. Due to its shape it allows large run out and angular movement. I'll update this thread when I get my machine finished. Just the E/stop circuit and vacuum to sort out. Regards Dale |
| Hi Dale, I will have to try that !!! Repeatability looks good, so I cant see a problem in cutting.I work mainly with wood but would like to see how your idea works out. I'm from Sunderland originally been in Canada since 1970.......... how are you enjoying the snow????? |
Hi, just an update on the band coupling. After trials I did notice some unwanted twisting on the coupling when machining roughing cuts. I did think of doubling up using two sheets of material per coupling. But opted to make the new band coupling from solid 40mm nylon bar. After a few trails I found that a 2mm ( .08") wall thickness works best. See uploaded images. This design still gives good angle misalignment and some run-out, but resists twisting very well. This was done in two ops, second op just had to turn the bar 90 degrees. Kind regards Dale |
#10
| Hello Dale, That is an interesting coupler idea and your results seem to show it is working well. Thanks for posting the idea and pictures, and please do some follow up feedback when you have time to see how it works over some time of acutal cutting. Regards,
__________________ Regards, Wes |
#11
| Radial twisting of the ends causes a diagonal flexion of the center "plate". If you made the center plate much thicker, it would still allow the desired displacements but greatly reduce the unwanted radial flex. So I would make the centre plate maybe 4 times thicker than the 2mm thick side walls. |
| Motor Coupling Question | whitehedr | Benchtop Machines | 1 | 12-17-2009 01:59 PM |
| Little slop in motor/ballscrew coupling ok? | brgrii | Linear and Rotary Motion | 0 | 09-03-2009 07:10 AM |
| Motor to leadscrew coupling help | Ranscon | Linear and Rotary Motion | 2 | 10-31-2008 09:38 PM |
| Metric to Inch motor coupling? | walter | DIY-CNC Router Table Machines | 1 | 08-22-2005 04:49 PM |
| ideas for motor coupling? | btarro | DIY-CNC Router Table Machines | 11 | 05-05-2005 09:31 AM |
