Old 01-04-2010, 10:03 AM
Liander is on a distinguished road
Material for Build
Hello everyone,
since I've finally got my electronics in working order and neatly (sort of) arranged them in a rackmount box I now need to pair them with a machine.
My main interest is building guitars and r/c models, so the ideal size of the machine is 1000mm x 550mm x 450 mm (above that I simply have no room where I can put it).
Materials which I intend to work regularly are hard woods and miscellaneous plastics.
I also would require to periodically work on small detail parts in aluminium up to 1cm (13/32" circa) thick.
My preliminary design is the following:
[all structural parts are 20mm thick, screws are 12x3 TPN with nylatron nuts, kress 1050 motor]
I've done a few calculations but, since I lack experience with automated machinery, which material you would advise me to use for the structure considering I require at least 1/10th of a mm precision and similar magnitude accuracy?
Since It would be primarily used for hobby purposes speed (or lack thereof) is not an issue.
Thanks in advance for your insight!
Tim
Timothy Tramontin
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-07-2011 11:16 PM
NEW BUILD: PVC as a build material Smiler DIY-CNC Router Table Machines 12 11-13-2009 04:57 PM
Now Hiring to build a 4'X4" router $500 + material costs-RFQ midevilone Employment Opportunity 2 11-18-2008 07:21 PM
Baltic Birch ply + MDF build, which material for which part nicanor76 DIY-CNC Router Table Machines 6 06-25-2008 06:21 AM
