Old 12-28-2009, 12:10 AM
ironman014's Avatar
ironman014 is on a distinguished road
vacuum table question
I have a new job i just started and i'm a little lost. I am use to Hass mills cutting metal and now i am using a gantry style router with a vacuum table with mach3 software.
My question is:
#1.the vacuum pump has a water tank what's with that
#2 the water starts to get worm (too hot to touch the tank but does not burn)
#3 the vent stack (direct off the tank) seems to have a high volume of steam. Is this normal.
#4 the pump does not sound good ( cavitation ) when i do a good job sealing the table should their be some flow/leakage to help the pump?
this pump i believe came from china and their is not one marking in it. No brand name, no electrical spec, nothing
any help would be appreciated
Mike
Old 12-28-2009, 07:39 AM
ger21's Avatar
There's some talk about a pump like that here, between maybe post #15 and #33.
http://www.cnczone.com/forums/showthread.php?t=91514
Old 12-29-2009, 01:22 AM
ironman014's Avatar
thanks so much
Thank you very much. You saved me a lot of time.
Old 12-29-2009, 01:23 AM
ironman014's Avatar
liquid ring vacuum pump help
now on to learn proper operation.
Vacuum table and vacuum pump garagefela DIY-CNC Router Table Machines 19 01-25-2012 10:30 AM
yet another vacuum table question.... boomerize DIY-CNC Router Table Machines 9 08-18-2009 12:16 PM
Need Help!- vacuum table Todd W DIY-CNC Router Table Machines 0 07-11-2008 11:42 AM
DIY Vacuum Table Baudros DIY-CNC Router Table Machines 5 04-07-2007 12:57 AM
Vacuum table balsaman DIY-CNC Router Table Machines 11 01-05-2004 08:18 AM
