Old 12-26-2009, 04:59 PM
MBG MBG is offline
MBG is on a distinguished road
DIY CNC laser engravers
Does anybody know where I can get plans for a CNC laser engraver?
I found a spot where I can get the electronics plan but not the mechanical
Old 12-26-2009, 05:00 PM
MBG MBG is offline
The company supplying me the electronics plan is supply motion TEK.
Old 12-27-2009, 12:18 AM
FandZ's Avatar
FandZ is on a distinguished road
As long as your table isn't flammable, any cnc would do AFAIK. Since your not concerned with cutting forces, it doesn't have to be built like a tank. You will want some speed though.
When I was researching it though, I dropped the idea quickly. Lasers with power enough to cut beyond a few mm get expansive very fast. The only ones I saw with the power I would have wanted were in the 10 to 20k range. I've seen a couple of laser builds here on the zone. You may want to search forums. I haven't seen any DIY builds where they were cutting anything beyond cardboard though.
Old 12-27-2009, 08:57 AM
MBG MBG is offline
Okay, if the laser is to expensive to cut then I will stick with a large engraver to engrave marble and other stone.
Old 12-27-2009, 07:41 PM
MBG MBG is offline
what is AFAIK??
Old 12-27-2009, 08:14 PM
MyCattMaxx's Avatar
MyCattMaxx is on a distinguished road
Originally Posted by MBG View Post
what is AFAIK??
As far as I know
Need Help!- Inexpensive Laser Cutters/Engravers hubery Laser Engraving & Cutting Machines 2 07-14-2009 09:52 AM
Newbie- Guide and references for laser engravers SHADOW042 Laser Engraving & Cutting Machines 2 07-14-2009 01:53 AM
Laser Engravers (again) RayUK Want To Buy...Need help! 2 01-02-2009 01:21 AM
ITOP--CNC ROUTERS, LASER ENGRAVERS, LASER CUTTING MACHINES, CNC PLASMA CUTTERS oliver9866 Product Announcements & Manufacturer News 0 10-17-2008 10:17 AM
laser engravers in the u.k hpc laser u.k Laser Engraving & Cutting Machines 1 03-28-2007 04:44 AM
