Hello, I am in the process of researching how to make my own mobile gauntry cnc plotter. I am trying to figure out what is the simplest up/down Z axis solution. I found a lot of complex designs where the Z positioning has a large travel through a a lead screw, but I need something really simple. Could someone point me to something like a plotter? Thanks, Frank |
| Hi Frank If the plotter is always writing on a single XY plane, then any mechanism to remove the pen tip from the plane should work, no? What about a simple $10 PWM servo (the type that RC modelers and robotics hobby folks use) that would swing the pen away from the writing plane? A solenoid may work, bu the travel is usually very short, and they would heat up when energized for long periods of time. Cheers! Paul Rowntree |
CarveOne
__________________ CarveOne Resistance is not futile. It is voltage divided by current (R=V/I). |
| Tubular solenoids come in push or pull types. An R/C servo will work but you need a way to operate it. The simplest way I know of is to use an R/C servo tester that can be purchased. No transmitter or receiver is necessary that way. The pen holder can have a ball point pen spring inside to provide the preload function. I made a spring loaded BIC pen holder in one of the threads in this forum sometime during 2009. It was just a K&S brass tube that was sized to fit a BIC ballpoint pen. CarveOne
| Parallax Inc. (www.parallax.com) sells several microcontrolers that can provide PWM outputs to drive small servos. I have used the Propeller Protoboard to drive them... software is free via the Object Exchange. Cost would be ~$55 for controller, power supply, servo. Cheers! pr Last edited by PaulRowntree; 12-30-2009 at 08:34 PM. Reason: clarifications |
| Mobile base for IH Mill | ProGunOne | Industrial Hobbies (Support forum) | 6 | 01-16-2008 04:03 PM |
| dnc & windows mobile | chrisryn | Machine Problems, Solutions , Wireless DNC, serial port | 2 | 09-28-2007 08:00 AM |
| Weight of mobile parts | Cherezov Oleg | Mechanical Calculations/Engineering Design | 6 | 04-30-2007 05:35 AM |
| Mobile base for the IH: any ideas? | deaeni | Industrial Hobbies (Support forum) | 0 | 07-30-2006 08:25 AM |
| Zen, CNC, and Mobile Robots | ToyMaker | RC Robotics & Autonomous Robots | 12 | 02-06-2005 04:39 PM |
