12-24-2009, 11:05 PM
Originally Posted by jascamera Guys,
I have been working at designing aerial photography RC helicopters. I have been thinking about purchasing a CNC machine, for making my parts, as I can have more control over my design, they are all 2D parts. But I am not certain how complicated and how many more machines that I will need to finish my parts. The frame parts are no Thicker than 0.09" think sheets of 6061, 7075 aluminum and carbon fiber. I will aslo need this machine to be able to cut sheets at a minimum of 12"x14" with a tolerance of 0.01"(ideally).
If it's possible such machine can also cut 1/4" inter joining parts make of 1/4" 6061 aluminum would be ideal, but not a must.
Is there such a machine will fit my requirement and at a reasonable price? Or any DIY kits out there with such specs?
Here is a photo of parts that I am trying to make, will fit perfectly on 12" x 24" sheet aluminum. http://www.jasonlamphotography.com/600.jpg
Jason |
I would think many of the better built all metal router tables would work for you. I can cut Aluminum and hold around .005" for a smaller part with my all metal 16" x 30" DIY router table.
You could pick up a used one for around $1500 no problem, perhaps a lot less.
Do you want to DIY or buy a pre made unit? |
