| rud: that is correct: in general if the weight of the material plus table is greater than the weight of the gantry, then move the gantry. other factors to consider are machine stiffness and desired accuracy. robotic regards, Tom = = = = = “Here are all kinds of employers wanting all sorts of servants, and all sorts of servants wanting all kinds of employers, and they never seem to come together.” - - Charles Dickens, English writer |
| Rud: The trade-off is that for a given amount of effort and expense, the moving table machine will be more rigid and more accurate; however for the same effort and expense the moving gantry machine will take up far less space. So, it boils down to accuracy and rigidity versus space.
__________________ Patrick; The Sober Pollock |
| ok thanks guys, just to make sure... moving table is more accurate ? and I think I can use 1 motor for moving table, compare if I'm using moving gantry may be use 2 motor. thanks guys i'm trying to make one, collecting parts cheap... take times. |
The part most prone to changes in weight should be stationary so the moving masses are more consistant for accuracy. A lighter weight can be accelerated more rapidly for performance. Machine Parts move towards each other, it is irrelevant wich one actually moves the important thing is the design and support of the elements that guide the transitions and there spacing towards each other that have most impact on stiffness and accuracy. Of course Floor space may also be something to consider. |
| Trade offs between Moving Gantry and Moving Table | gregmary | DIY-CNC Router Table Machines | 11 | 04-22-2011 01:48 PM |
| Newbie - To build or not to build Router/Plasma Table | dfranks | CNC Plasma and Waterjet Machines | 10 | 04-07-2011 11:16 PM |
| Moving Table vs Moving Gantry; Dremel vs Router | chuckknigh | DIY-CNC Router Table Machines | 32 | 03-27-2007 08:48 PM |
| Moveable Gantry or Table? | barkster | DIY-CNC Router Table Machines | 4 | 11-08-2004 07:26 PM |
| Moving Gantry Or Moving Table | DDM | DIY-CNC Router Table Machines | 9 | 04-28-2004 10:46 PM |
