Old 12-24-2009, 10:49 AM
Rogge is on a distinguished road
5X12X4 Gantry router for foam milling
I've been meaning to post to this forum for a while now. About two years back I spent a lot of time on these pages, and I learned tons from all the wonderful people who have posted about their experiences. Here is a brief description and a few pictures of what a group of engineering students from UIowa were able to accomplish with the help of all the people who post to these pages.
The machine that we built is a foam-cutting gantry router for milling plugs for fiberglass mold making. The dimensions are large - 5' X 12' X 4'. The plugs that we make are used to make molds for fiberglass fairings for recumbent, solar-powered bicycles (check out www.iowasolarbike.org). The frame is 2" angle iron, and the gantry is 2" aluminum square tube. The linear bearings for the X axis were custom - a piece of 2" steel square tubing set at 45 degrees (diamond shape) with v-groove wheels that run along the top and bottom of the tube. The bearings for Y and Z were standard 20mm rail and blocks from VBX bearings. Drive for X is a chain drive, Y and Z got ACME leadscrews. Interestingly, the chain drive (which we thought would be a weak link) turned out to be the smoothest drive of all (whipping from the lead screws limits us to 80 ipm travels in Y and Z). We easily get 500 ipm on the X axis.
We write our code (and develop the CAD models) in Pro E - and I'll make a little plug here - Pro E may be a little tricky to learn (esp the CAM) but once you learn it, it is fantastic.
The machine holds .010 tolerances, repeatability is considerably better that than. For what we do, .100 is plenty.
All in all we spent around $2500-3000 on the project. It was ALMOST more fun that riding the bikes at 50 mph...
ID:	95999   Click image for larger version
ID:	96000   Click image for larger version
ID:	96001   Click image for larger version
ID:	96003   Click image for larger version
Old 12-24-2009, 10:58 AM
ZOB ZOB is offline
ZOB is on a distinguished road
That is awesome, well done.
Old 12-24-2009, 04:05 PM
eloid is on a distinguished road
what glue did you use the glue up the 2" foam sheet to gethere? also interested what you used to protect the foam as a barrier / coating, fiberglas resin eat up foam on contact?
Old 12-24-2009, 06:38 PM
Telly is on a distinguished road
Sir, I need a longer upcut spiral bit....please
Very nice work!
Old 12-24-2009, 08:16 PM
CarveOne is on a distinguished road
West System slow cure epoxy does not melt pink, blue, or white foam. In my own work I use #105 resin and #206 hardener with fiberglass cloth as a barrier. Use the same epoxy for gluing the foam layers. Just squeege on a thin layer and apply weights to keep it firmly pressed together until cured.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Old 12-25-2009, 07:40 PM
We used epoxy (System Three Silvertip - a little nicer to work with than West System) to stack the foam up. Then we did a skin coat of epoxy/microballoon filler on the foam plug followed by a coat of DP90 epoxy primer before gelcoat to keep the foam and gelcoat from interacting. A better method would be to use faom that has no problem with polyester resins (gelcoat). I can't remember the name of the foam, but it is the stuff you find on the inside of the foil-faced foam panels. Cyano-something-or-other.
Old 12-25-2009, 08:03 PM
advt001 is on a distinguished road
Rogge in pic#4 (showing the tool cutting the foam)where did you get the long tool?
Old 12-26-2009, 05:16 PM
We made that tool by pressing a 1/2" ball nose endmill onto a chromoly shaft. It was pretty well balanced - we did a little straightening and then threw it in the router. The spindle bearings seemed to hold up ok (we've only run this machine for maybe 50 hours total).
Old 11-18-2010, 05:27 PM
z321 is on a distinguished road
what design did you follow for your machine?
I am just curious as to what design you followed in the build for your machine.
The machine that we built is a foam-cutting gantry router for milling plugs for fiberglass mold making. The dimensions are large - 5' X 12' X 4'. The plugs that we make are used to make molds for fiberglass fairings for recumbent, solar-powered bicycles (check out Web Template). The frame is 2" angle iron, and the gantry is 2" aluminum square tube. The linear bearings for the X axis were custom - a piece of 2" steel square tubing set at 45 degrees (diamond shape) with v-groove wheels that run along the top and bottom of the tube. The bearings for Y and Z were standard 20mm rail and blocks from VBX bearings. Drive for X is a chain drive, Y and Z got ACME leadscrews. Interestingly, the chain drive (which we thought would be a weak link) turned out to be the smoothest drive of all (whipping from the lead screws limits us to 80 ipm travels in Y and Z). We easily get 500 ipm on the X axis.
New Machine Build- Fixed gantry router KTP DIY-CNC Router Table Machines 25 04-17-2011 05:44 PM
Newbie- 4' X - 8' Y (Gantry) Router Table jz2hs6 DIY-CNC Router Table Machines 1 09-08-2009 06:45 AM
New Gantry Router Halfnutz CNC Wood Router Project Log 57 03-01-2008 02:54 PM
Gantry Router Log Rodm1954 CNC Wood Router Project Log 43 12-30-2006 12:09 AM
Vertical Gantry Router jdownie DIY-CNC Router Table Machines 4 10-26-2005 06:17 PM
