Old 12-23-2009, 06:55 PM
bhdavis1cnc is on a distinguished road
Building a bleed board hold down for sheet stock
I have a CNT Motion 900 5x10 cnc. Since we primarily make hardwood parts our hold down system consists of an MDF table surface and screw down pods. An SL-Laser provides the layout for pod placement.
Occasionally though I want to cut some sheet stock. This can be done with pods, or carefully located screws to hold down the sheet. However I'd really like to have a bleed through system for these occasions.
I've already cut a couple 4' x 4' x 3/4" base grids and have a plan to access these 2 panels with 3" vacuum lines once they are set on the 5x10 MDF table. I can put either one or both 4'x 4' panels on the cnc depending upon what size material I need to cut.
The question I have for you more experienced folks is just how small a regenerative blower can I get by with for each of the 4' x 4' bleed board sections. I was thinking that perhaps 2 smaller blowers might be the way to go, but one large blower would be fine too. Since this isn't going to be used very often I obviously don't intend to spend $3k to $5k (or more) on a vacuum pump or regenerative blower. My pump for the pod system is a 5hp rotary vane pump that pulls 26" and a low air volume so won't work with the bleed through panels.
Thanks for any guidance you can provide.
BH
Best way to organize and load sheet stock in a small shop? douglasco CNC Plasma and Waterjet Machines 2 10-31-2008 09:19 PM
How do you hold sheet material? cnczoner General Metal Working Machines 12 08-18-2008 12:29 PM
How do you hold down a sheet of alum? UBRacing DIY-CNC Router Table Machines 5 07-10-2007 03:07 PM
Sheet stock lifting. fer_mayrl WoodWorking 2 05-01-2007 12:38 PM
Building Phils sla7051 board TinkerDJ Open Source Controller Boards 9 05-09-2005 01:16 PM
