Old 12-22-2009, 01:31 PM
JohnnyVegas's Avatar
JohnnyVegas is on a distinguished road
Bosch colt router Dimension / Measurements Please :)
I have a new Bosh Colt on it way and was wondering if anyone can share diameter measurement?
I am building my table and would like to cut the holder for it but don't have the physical router just yet.
Old 12-22-2009, 05:50 PM
leggazoid is on a distinguished road
Could someone please post this measurement? I think it is 2-1/2 inches in diameter.
Regards,
Ken
Old 12-23-2009, 11:41 PM
So I went in a store and pulled the base off the display router. With a VERY rough measurement I'm getting around 2 13/16" - 2 7/8". That's all I needed to know. I'll cut for it when it arrives.
Old 12-24-2009, 11:55 AM
FandZ's Avatar
FandZ is on a distinguished road
Once you get it in and and are able to get an accurate measurement, please post the dimensions. You may help someone down the road.
Old 12-24-2009, 01:04 PM
Grunblau's Avatar
Grunblau is on a distinguished road
I would be interested too. I posted the 3D model I made of of my Bosch router. I am currently designing a new CNC around the Colt. If anyone had the critical dimensions I would really appreciate it!!
My 3D bosch file...
http://www.grunblau.com/downloadsbmo.htm
Old 12-26-2009, 06:42 PM
My 3D bosch file...
I received it on Christmas eve~!! Haven't opened it yet. I will get the basic measurements and post here soon. Does anyone need anything other then the diameter?
thanks
Old 12-26-2009, 07:16 PM
FandZ's Avatar
The mounting surface height would be a good idea too
Old 12-26-2009, 07:25 PM
Ok here's what I got. All in "mm"
Easier to post pics then to describe!
FYI, If someone makes a working file using these dimensions, please be kind and post it here.
**with base**
ID:	96129Click image for larger version
**Base OFF** / rear grip height
ID:	96131Click image for larger version
*Front grip height / Base to Col
ID:	96133Click image for larger version
ID:	96135Click image for larger version
Old 12-26-2009, 07:34 PM
BTW, this is one nice router. Quite and runs MUCH better then anticipated. Great buy. I may get a little crazy and use it as a trim router on my machine tonight! LOL
Old 12-26-2009, 07:40 PM
Thanks Grunblau for the DIY cable track. I was just about to try and work up something similar when my machine was finished. Excellent. Have you cut this yet? Have a pic? Are these glued when complete?
  #11   Ban this user!
Old 09-25-2010, 10:05 PM
serandre is on a distinguished road
Here we go...
Thanks so MUCH for sharing the dimensions, this was very usefull, so I have made a mount for the colt.
If you need the 3d Model, just go to Google Sketchup 3D Warehouse, I have shared the model there "Bosch Colt Mount"
ID:	115490   Click image for larger version
ID:	115491   Click image for larger version
ID:	115492   Click image for larger version
  #12   Ban this user!
Old 09-26-2010, 09:59 AM
CarbonKevin is on a distinguished road
I don't know if this is a reasonable alternative or not, but K2 in the US makes a very good clamping holder for the Bosch Colt...buy one of those and devote your time elsewhere, perhaps?
It would guarantee you a working clamp, no need to worry about tolerances, fit, etc.
ck
Bosch Colt router and 1/8" collet alecu7 DIY-CNC Router Table Machines 5 03-14-2010 07:41 PM
Colt Bosch Spindle John Bear Ross Taig Mills & Lathes 37 02-08-2010 11:30 AM
What size motors using bosch colt, linear bearing rails, 24" 3/8-16 acme screws? ink251 DIY-CNC Router Table Machines 0 09-02-2009 08:50 PM
Colt™ Variable-speed Palm Router Kit justCNCit DIY-CNC Router Table Machines 2 02-16-2009 12:14 AM
Gerber Dimension 200E CNC Router with engraving head vipers95 Commercial CNC Wood Routers 4 02-14-2009 08:08 PM
