Old 12-20-2009, 01:00 PM
purecnc's Avatar
purecnc is on a distinguished road
Talking Easy cnc
Hi im 14 years old and I started to build my first cnc machine based off Tom McWires insructable http://www.instructables.com/id/Easy...lling-Machine/
but im making it bigger to have a cutting table of 11x11in.
And I have a question to ask.
1. here are the motors im using http://www.mpja.com/prodinfo.asp?number=17757+MS what voltage and amps should i use for my power supply
"I can do all things through Jesus Christs who strengthens me." (Phi 4:13)
<>< Mr.D's CNC ><>
Old 12-20-2009, 02:25 PM
leggazoid is on a distinguished road
Power supply specs are dependent on the stepper driver you will use. Is it chopper or PWM type? Is it the light bulb design from mcwire?
http://www.mpja.com/prodinfo.asp?number=18091+PS may work but need more detail about your electronics.
To start out on the cheap a modified computer power supply will work.
Old 12-20-2009, 04:18 PM
purecnc's Avatar
Im going to use this instructable http://www.instructables.com/id/Easy..._a_Recycled_M/
with turbo cnc and if that doesn't work i will have to chose to build Tom McWires controller or buy the EZ stepper from Hobbycnc
<>< Mr.D's CNC ><>
Old 12-20-2009, 07:35 PM
purecnc's Avatar
Talking Pictures
was working in a freezing cold (32f) shop today and i got some pics.
ID:	95621   Click image for larger version
ID:	95622   Click image for larger version
ID:	95623   Click image for larger version
ID:	95625   Click image for larger version
ID:	95626   Click image for larger version
ID:	95627   Click image for larger version
ID:	95629   Click image for larger version
ID:	95630   Click image for larger version
ID:	95631   Click image for larger version
ID:	95633   Click image for larger version
ID:	95634   Click image for larger version
ID:	95635   Click image for larger version
ID:	95637   Click image for larger version
ID:	95638   Click image for larger version
ID:	95639   Click image for larger version
<>< Mr.D's CNC ><>
Old 12-22-2009, 08:13 PM
purecnc's Avatar
Talking
worked today in shop and heres some pictures.
and heres a youtube video
(Sorry for the bad quality it was taken from my phone)
ID:	95834   Click image for larger version
ID:	95835   Click image for larger version
ID:	95836   Click image for larger version
ID:	95838   Click image for larger version
ID:	95839   Click image for larger version
ID:	95840   Click image for larger version
<>< Mr.D's CNC ><>
Old 12-22-2009, 10:58 PM
FandZ's Avatar
FandZ is on a distinguished road
Your so young to have such and evil addiction. Quick, get out. Save yourself while you still can. lol Welcome aboard. Looks like you are making quick progress. Let me ask you, what holds the wood down on the rails? From the pictures it looks like the wood just travels on the U shape extrusions. Is that how it works?
Old 12-23-2009, 12:56 PM
purecnc's Avatar
Talking
I use simple aluminum "C" channel and the wood is held down by 1\4in bolts also the X and Y axis are not held down by anything like the Z axis is held by skate board bearings.
<>< Mr.D's CNC ><>
Old 12-24-2009, 12:06 PM
murray is on a distinguished road
Make sure that your motors are under 500ma each. My motors are 1.2A each, so I have to make a new design.
The machine is looking great, keep up the good work.
Visit my website at http://colvins.ca
"Remember that duct tape takes over when skill leaves off!"
Old 12-24-2009, 12:21 PM
purecnc's Avatar
Talking
Heres what the spec for my mototrs are murray.
MFG: SHINANO KENSHI
P/N: STP42D241
COIL: 12V/3.1 ohm/2.9mH
TYPE: 2 Phase Uni-Polar 6 lead
STEP ANGLE: 1.8 deg 200step/rev
5mm dia. X 24mm steel shaft with metal 20 tooth X 11/16" dia. gear & 22 tooth X 9/16" dia. cog belt pully. 4 corner m3x0.5 mounting holes. 5" leads.
L: 1-5/8" (Body) SQ: 1-9/16” WT: .64
<>< Mr.D's CNC ><>
Old 12-24-2009, 06:29 PM
purecnc's Avatar
Talking pictures
worked in the shop yesterday and today and got the X Y Z axis's all on but i have to do some tweeking.
heres some more pictures.
and heres a youtube video of it cutting.(im manually moving the steppers)
ID:	96014   Click image for larger version
ID:	96015   Click image for larger version
ID:	96016   Click image for larger version
ID:	96018   Click image for larger version
ID:	96019   Click image for larger version
ID:	96020   Click image for larger version
ID:	96022   Click image for larger version
ID:	96023   Click image for larger version
ID:	96024   Click image for larger version
<>< Mr.D's CNC ><>
  #11   Ban this user!
Old 02-17-2010, 02:45 PM
purecnc's Avatar
Unhappy
I have been having problems with my stepper drive so it will be awhile before i get this running.
<>< Mr.D's CNC ><>
MastercamX not so easy with easy projects X7racer Mastercam 7 05-21-2008 09:28 PM
This should be easy... Robin Hewitt G-Code Programing 7 05-30-2007 02:56 PM
easy for some, skydivebase OneCNC 3 05-27-2007 08:36 AM
Easy CNC and Easy Stepp'n kylecroft CNCzone Club House 5 02-18-2007 11:54 AM
Please be easy, I'm new sin-city-custom General Metal Working Machines 4 03-01-2005 10:20 AM
