Old 12-16-2009, 11:41 PM
nicanor76 is on a distinguished road
upgraded thread, now Mach3 changes distance after loading files
I'm building an experimental CNC so I created a new profile in Mach3 so I can use both old and new. The new one is faster (8 start Acme) so have it tuned that way in Mach 3. All is well, if I want it to job an inch it moves an inch physically and in the software). The problem comes when I load a file; when I want to job an inch it moves an inch physically but only a small percentage in the software (like .1 inch). So I can't run any old or new files in the new machine since the slides goes off limits.
I found 1 old file that works fine. But if I load a 2nd file to test out, it's screwed up again, reload the working file and the "settings" remain screwed up. Will have to reset the program to make it job correctly again.
Any ideas, need help!
Old 12-16-2009, 11:46 PM
ger21's Avatar
your units may be set wrong. Does your code have G20 or G21 at the start?
Old 12-17-2009, 12:24 AM
neilw20's Avatar
neilw20 is on a distinguished road
Save the settings.
In Mach3, at the bottom of the second drop-down menu have you saved config?
I am using multiple settings for screws in multiple profiles without a problem.
As command line arumentg in shortcut: Mach3 /p "profile name"
Or used the Mach3 loader which handles multiple profiles. Mine works correctly either way.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 12-17-2009, 09:11 AM
I think the code starts with G20? Here's the 1st few lines:
"N1G00G17G40G49G80G90G94G98
N2G20T1M06
N3G90G00X4.62762Y2.55316S4583M03
N4G43Z0.575H0
N5G01Z0.45F7"
I use multiple profiles at the start of Mach3, old profile for old CNC and different profile for the new one. I wonder if it somehow changes from imperial to metric? I'll double check the settings again later today.
Old 12-17-2009, 09:22 AM
ger21's Avatar
Go to Config>Set Native Units and check there.
Mach3 and .stp files Sandiapaul Mach Software (ArtSoft software) 1 12-13-2009 09:06 AM
Need Help!- getting STL files into Mach3 Drools General CAM Discussion 2 09-08-2009 01:53 PM
Mach3 config files Konstantin Mach Software (ArtSoft software) 0 05-15-2009 01:42 PM
New to EMC2, New to Linux Trouble loading SIM files CalG LinuxCNC (formerly EMC2) 31 03-22-2009 07:25 AM
Mach 2 not loading files JFettig Mach Software (ArtSoft software) 3 11-10-2007 03:35 AM
