I know there is a medium to fill the holes I have created in my mdf table. I could use body filler however as I have over 90 holes that are about 12" oval and 1/2" deep in the top of my table where I have inserted my pervious gasket pattern. Yes it is a large table 9' x 28' and I want to change my gasket pattern after 18 months of using the present configuration. I was thinking it is some kind of miodeler medium that was used at one time? |
CarveOne
__________________ CarveOne Resistance is not futile. It is voltage divided by current (R=V/I). |
| My first thought was "just buy a new sheet of MDF for $25", then I saw your machine dimensions! 9'x28' = 7+ sheets. Ok, so patching makes sense, but factoring in all the time and materials - that's a tough call. Steve |
| Thanks Carveone, Thats one solution I found on the website but the only mdf I have in my shop is the 2" mdf on my CNC table, that costs around $100 sheet Canadian (that used to be $25 US). When the company that first tried to build my vacumn system screwed up and routed a wrong pattern they had a blue coloured ( ("colored" if I was American) medium that I thought they got from a modeling place (like a place that they build movie models and mock-ups) Drywall mud will just crack as I am moving 2x10/ 2x12 20'-24' material on and off the machine 10 times a day and it isn't a gently exercise. Thanks for all your input. |
| Drywall putty will dull the cutters if it has any silica in the formulation. It has a longer setup time also. CarveOne
Michaels the craft store carries several different modeling mediums including Delight and several other paper base products. They open in a couple of hours and I'll let you know how it works. |
| I'd patch it with MDF, and fill the joints with thickened epoxy, which will adhere better than bondo, and is much harder. It is more expensive, though.
#10
#11
| For the holes, have your router make pockets at each hole location (or use a plunge router by hand) and then use a poplar dowel to make plugs to epoxy in place. This will save on the epoxy needed and the poplar plug is not much different in density than the MDF. Epoxy fill the gouged areas. CarveOne
#12
| Where do you get 12" oval dowels?
| SMTC Oil Fill? | big_mak | Haas Mills | 8 | 03-21-2011 06:54 PM |
| Newbie- fill holes | weirdharold | UG NX | 4 | 07-08-2009 02:49 AM |
| Need Help!- Pocket / fill | kghinsr | BobCad-Cam | 10 | 06-02-2008 08:47 AM |
| Hole fill? | pp-TG | Mastercam | 6 | 03-15-2007 03:59 AM |
| dxf to G-code...how to fill? | UCFMems | Autodesk Software (Autocad, Inventor etc) | 6 | 06-25-2004 11:26 AM |
