Old 12-14-2009, 01:15 PM
Ferrari2007 is on a distinguished road
Setting the backlash on End block
I am using thompson ball screw, ball nut and end block for both my X and Y axis.
Recently connected the motors and have everything moving properly.
Does anyone know the procedure for setting the proper backlash on the end block?
I am not certain what the tolerance should be?
Old 12-16-2009, 01:32 PM
LazyMan is on a distinguished road
There should be zero backlash in a fixed end block. There is a specified torque (you will need torque wrench) for the nut or preload in the manual. I would preload no more than 10% of the max axial load rating on the fixed end block. Ten Percent seems to be the max recommended by ballscrew manufactures in general for preloading their ballnuts and I imagine would they recommend for ball nuts would be similar.
Or you can do what I did. Tighten it down until there is no backlash and everything spins nice and free.
Old 12-16-2009, 02:30 PM
Thanks for the reply, I was most likely going to go with the second option and tighten it till it "feels" good. Which brings me to my second question...what type of wrench to use...
I have a torque wrench, but any idea on what these type of nuts are called? It looks like it takes a type of "spanner" wrench for lack of a better term.
touch probe/Z0 setting block advice dougie329 Controller & Computer Solutions 1 11-18-2009 03:44 PM
Need Help!- Setting Backlash with Turbocnc ecope TurboCNC 2 10-11-2009 02:36 PM
Backlash or motor tuning problem? How do I test for backlash? Brian Queen Mach Mill 8 03-10-2008 03:35 PM
Servo idea - elimated backlash - zero backlash ! synthetiklone Linear and Rotary Motion 6 12-06-2006 01:35 PM
RS232 program block by block smoregrava General CNC (Mill and Lathe) Control Software (NC) 3 12-22-2005 12:52 AM
