Old 12-13-2009, 04:47 PM
lasterixsuedois is on a distinguished road
Question Router, spindle power?
How do you calculate, estimate the nedeed power from the Router, spindle?
I have calculated my stalling cutting force to about 1200N (steppers stalling).
Practical cutting force under speed might be around 600N?!
I suppose there is a correlation between cutting force, material to be cut, etc and nedeed spindle power?
could some one explain this relationship, and give me a estimate on what spindle power would be reasonable?
Old 12-13-2009, 04:58 PM
ger21's Avatar
Cutting force depends on what material your cutting, how much your cutting at once, what tooling your using, and how fast your going. You ned to provide that info to get an answer on what size spindle you need.
Old 12-15-2009, 03:41 PM
Hmm, I was thinking of mainly cutting plywood and composites for kajaks and small boats (the cutting area is 1100X900).
Will a 1Hp router, spindle be enough to cut 6mm plywood at 2-4m/min in a single pass?
Old 12-16-2009, 03:42 AM
draughted's Avatar
draughted is on a distinguished road
you'll have to look in an engineering manual but the actual force of a stepper motor will be severly deminished by the screw. with action much like driving a wedge uphill including friction and every thing
my two newton metre, or 260 oz/inch steppers transmitt roughly 100 newtons through a ballscrew of 5mm pitch.
Old 12-16-2009, 03:45 AM
draughted's Avatar
on the spindle give it a bigger cutter dia and it probably could
maybe a bit fast.
3/8 to 1/2 inch dia that is
Old 12-16-2009, 07:27 AM
ger21's Avatar
Possibly, but I'd recommend at least 2HP.
Help with my DIY router power supply studysession DIY-CNC Router Table Machines 4 11-26-2008 07:31 PM
Spindle Power Curves TMTCamCentre Haas Mills 10 08-25-2008 07:25 PM
Power for your router Drakkn DIY-CNC Router Table Machines 3 12-03-2007 04:20 PM
Spindle Power Issues thackman Syil Products 7 12-01-2007 02:57 AM
Spindle power by servo motor Stevie General Metal Working Machines 4 04-18-2004 02:20 PM
