Hi all, I have a piece of 1/4inch cold rolled steel plate that I want to engrave some drill points on. Basically I'm going to be engraving some feeler spots for my punch to grab on to before I run it under the drill press. I've done this before and took too deep of cuts. What depth should I engrave it at? I just want enough for my center punch to grab on to. Oh and I'm useing a 1/2 v bit to do it. Last edited by FandZ; 12-13-2009 at 11:51 AM. Reason: Bit I'm useing |
| I ended up trying .001, then I tried .002 and that did the trick. .0015 would have probably been best. Well I'm off to drill. I'll try and post some pictures of what I was doing later in case someone else down the road searches and wants to do the same thing. |
| Drill 5 axis - points and lines | jcnewbie | Mastercam | 2 | 10-18-2009 03:24 PM |
| Chipload for two flute slot drill in mild steel | LeonM | General Metalwork Discussion | 9 | 07-02-2009 05:37 PM |
| Problem- Adding drill points to a rectangle | Joe Rodney | Mastercam | 6 | 10-19-2008 03:35 PM |
| Using collet instead of drill chuck? for drilling steel | Rich05 | General Metalwork Discussion | 7 | 07-13-2008 10:53 PM |
| Can I drill AISI 1020 plate steel with a drill bit? | Apples | General Metalwork Discussion | 2 | 02-01-2006 11:15 AM |
