Hello again all! I am making progress on my first build and have gotten to the point where I need a little help. Im building a CNC for cutting small aluminum boxes (3"x4"), and PCB's. I have the bottom of the frame designed using Autocad 2008 with the 8020 add-on (im making the whole frame from 8020). Questions: a) I need to design the bed which holds the lead screw on the bottom... but I dont know how they mount. I imagine when I purchase the lead screw it will just be a rod and I will need to get 2 bearings? Is there a standard size or attachment method? Can someone fill in the details please ![]() b) I need to decide on a lead screw to purchase. I havent purchased an X or Y axis motor yet (I already own a 'Paul Jones instant Z-Axis Kit'). But I do not know how to properly decide what lead screws to get for my X and Y axis. I see alot of talk about IPM and speed/torque conversions, but I am new to this. I'm worried I may need to do something like gear up/down. Can someone please fill in the details on how I should proceed? Thanks for help in advance! I have attached a picture of the instant z-axis kit and also the Autocad design I have made thus far. J |
| Ive been reading alot through the forum and have come to the conclusion that a Recirculating Roller Screw would be the best option for precision. This is the link that sold me: http://www.linearmotion.skf.com/en/8...rews__SV_.html |
| Not sure if you'll find any homebuilt machines that use those. Extremely expensive, unless you can build your own. And the one in the link has a 1mm lead, which will give you an extremely slow machine. 1/2-8 2 start or 1/2-10 5 start acme are the most common choices. The 1/2-8 will give more resolution, but less speed. The 1/2-10 5 start will give less resolution, and more speed. If you don't have any idea how fast you want or need to cut, then one of the two choices I gave you will get you started at a reasonable price.
Oh are they not very common? I wish they had a price list... I was just looking at that link to get an understanding of that design. What does the "start" mean? im guessing the firs number is the width? 1/2"? and the "-8" is the pitch? |
| 1/2-8 2 start 1/2" diameter, 8 threads per inch. 2 start means there are two separate alternating threads, each with 4 turns per inch. So one turn of the screw moves 0.25".
| so the more starts the better? Is there a thickness rule for going 48 long"? I guess I should decide on the lead screw to purchase now so I can get dimensions for the proper fixed mount system... right now im not sure but im thinking something like 5/8" 4 start, sound good? I have no idea what inches per minute this will turn out to be, or what i need. |
| Help with lead screw & motor - 1st build near done | viroy | DIY-CNC Router Table Machines | 105 | 02-19-2010 01:12 PM |
| How do you mount a lead screw/lead nut? | jbluetooth | DIY-CNC Router Table Machines | 2 | 12-01-2008 04:10 PM |
| Belt vrs. Ball Screw vrs. Lead Screw | stevesplanes | Linear and Rotary Motion | 7 | 01-09-2006 11:23 AM |
| New technology.... old debate.....ball screw vs lead screw | trubleshtr | Linear and Rotary Motion | 1 | 08-15-2005 08:42 PM |
| Ball Screw or Lead Screw? Which is Better? | ljoe1969 | DIY-CNC Router Table Machines | 4 | 07-28-2004 08:49 AM |
