Old 12-11-2009, 11:36 AM
rkovvur is on a distinguished road
How are you cutting aluminum for the router frame
Hi All:
I am planning on making my first cnc router and got a real sweet deal on Bosch aluminum extrusions. But now i am scratching my head on the best way to cut it.
I've seen some people use the non-ferrous metal cutting blades on a miter saw. But i am not yet ready to plunk down $50 for the metal blade.
I am interested in hearing from what others have been doing to cut the metal accurately.
Old 12-11-2009, 11:58 AM
Santa Fe Al's Avatar
Santa Fe Al is on a distinguished road
Originally Posted by rkovvur View Post
Hi All:
Hi rkovvur,
Although I am fairly new to CNC, I built my Z-axis assembly using 1/2 inch aluminum 6061. To cut it, I used my radial arm saw with carbide tipped plywood (48 teeth, or more per inch) blade. All cuts were 1/16 to 1/8 inches deep. A pain having to crank the blade height after every pass, but it worked great for me.
Don't forget to put on safety glasses. I had some small cuttings fly around a little bit.
Hope this helps
Al
Old 12-11-2009, 12:18 PM
ger21's Avatar
Any carbide tipped blade will cut aluminum. I'd recommend at least 60 teeth, and a triple chip tooth is best. For precise cuts, my preference would be a table saw with a sliding cutoff table.
Old 12-11-2009, 01:47 PM
Thanks!
Yup, it looks like all metal cutting blades are TCG. I am worrying that if i mount the blade on my miter saw, will i have problem with the speed. Do metal cutting blades need to be run slower?
Old 12-11-2009, 02:07 PM
harryn is on a distinguished road
I have a dewalt miter saw and used just the normal carbide tipped blade. Having said that, I did cut it slowly, and big chips of Al fly all over - and I mean ALL OVER - including right back at your face.
Not only do I recommend safety glasses, but actually a face shield.
IMHO, and this is from a beginner - cutting Al is not so terribly different than cutting old growth hard maple or a hard oak.
I don't use the same wood blade to cut the Al as my normal wood though - so you really have not avoided buying a second blade.
Supporting RanaTeckk.com and their Dashboard for MS Project promo code WRLNT-2
Old 12-11-2009, 02:12 PM
rowbare is on a distinguished road
You can get away with cutting aluminum at the normal miter saw speed though ideally a slower speed is better. Dry cut metal saws usually run around 1300 rpm (albeit with a 14" blade) and cold saws around 300-400 rpm.
I have cut plenty of aluminum picture frame molding with mitre saw and have had good results. Using a wax lubrication stick will help: http://www.woodcraft.com/Product/200...Lubricant.aspx
bob
Old 12-11-2009, 02:14 PM
jalessi's Avatar
jalessi is on a distinguished road
Post
Rkovvur,
Apply a shot of WD-40 once in a while.
Using a smaller diameter blade may help also.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 12-11-2009, 03:59 PM
hemsworthlad is on a distinguished road
I have cut 20/20 and 6061 plate with my chop saw no problem, just use a tct blade and cut down slow and it will cut like butter.
You will need a full face shield and coverd arms the chips fly every where and stick.
I have even used my router hand held with fence to cut 1" deep channels with no problem, just lots of shallow cuts and again was very easy. . . . Scary as bloody hell at first but wounce i settled down relaxed my grip etc it was no harder than cutting any hard-hardwood, infact i used an old 2 flute 12.5 x 50mm tc wood bit.
Give it a try you will be amazed just how easy it cuts, a squirt of cutting fluid and really shallow cuts, I just started with scratch like cuts at first then just went deeper untill i felt comfortable.
Old 12-13-2009, 05:06 AM
viroy is on a distinguished road
I had some 3"x3" solid aluminum I needed cut at exactly 1.5"... I just looked up 'machining' in the yellow pages and called around.
I found several places that claimed could do it same day and accurately, cost $20 to cut 30 pieces and all were exactly on.
DIY Aluminum cnc router Frame gio666 Product Announcements & Manufacturer News 1473 08-07-2010 11:25 PM
Newbie- 4X8 CNC router cutting 3/16 aluminum sheet scorpionracing General Metal Working Machines 2 02-22-2010 03:47 PM
Cutting .020 Sheet Aluminum on a CNC Router Mini-MillX2 General Metalwork Discussion 12 05-01-2007 06:21 PM
Aluminum cutting router sdantonio General Metal Working Machines 7 03-28-2006 04:33 PM
CNC Router cutting Aluminum 2Gs DIY-CNC Router Table Machines 7 08-09-2004 08:21 AM
