Old 12-08-2009, 02:54 PM
oldhack is on a distinguished road
whats a reliable BOB to use with Geckos
Ive been at this about 3 weeks and no go yet.
Im having a lot of problems with the c11g acting properly. I know each setup is different. Im trying to work with Arturo to get things working but id rather have a simpler alternative. When I used to do animatronics, You hook up PS/Motor/Mechanics and run software. Thats what it took. (some knowledge also /grin)
My System :
Geckos work/PC works?ports work/PS works /Motors new (keling) C11g whacks out, so I want to try different software and/or a different reliable BOB. Is there any other windows based controller software out there? and which BOB works well with the Geckos?
Old 12-08-2009, 03:05 PM
ger21's Avatar
Other Windows software will require additional hardware
http://www.usbcnc.com/
http://www.wincnc.net/
http://www.flashcutcnc.com/index.php
The Campbell and PMDX boards are both supposed to be pretty good.
Old 12-08-2009, 05:20 PM
ill check them out better.
thanks
Old 12-08-2009, 08:52 PM
pimpbike's Avatar
pimpbike is on a distinguished road
What is the problem you're having with the C11G? Just curious...
Old 12-08-2009, 09:22 PM
marzetti is on a distinguished road
I just put together a system using a C10 board and had trouble with it. Arturo was very responsive but in the end I tracked it down to a bad parallel port on my computer. I switched to a different machine and the problem was solved. The software I used to diagnose the parallel port can be found here for free:[URL="http://geekhideout.com/parmon.shtml"]. Good luck!
servo setup whats need and whats do i need to know jhtmfg Benchtop Machines 0 10-09-2009 06:29 PM
Reliable Taig Dealers xela61 Taig Mills & Lathes 5 12-01-2008 02:03 PM
Are these Matsuuras' reliable??? teamjnz Knee Vertical Mills 0 08-15-2008 05:00 PM
Need reliable UK supplier for microtools LuckyStrike CNC Tooling 2 06-16-2008 11:15 AM
reliable place for motors? eloid CNC Wood Router Project Log 3 03-22-2007 07:11 PM
