Old 12-05-2009, 12:43 PM
analogman is on a distinguished road
Bit Slip on Chinese Spindle
During a very long operation (+1 hour), my 1/2" bit started to slip (down), ruining the job. Any suggestions on how I can prevent this from happening in the future? The collet was on very tight.
Old 12-05-2009, 12:51 PM
ger21's Avatar
Make sure both the bit and collet are very clean. If they are, then it wasn't tight enough.
Old 12-05-2009, 02:22 PM
LazyMan is on a distinguished road
Same thing happened to me once, but the bit came very loose and stopped cutting properly. Almost caused some serious damage. Ever since, I make sure the collet is super clean and tight when using larger bits.
Old 12-05-2009, 03:15 PM
giveinfo is on a distinguished road
I use Chinese spindle, it works for 5-6 hours without problems (8mm end mill).
Just clean it an tight it.
Old 12-05-2009, 04:23 PM
Thanks guys - yeah there was some dust in there. Cleaned it spotless - that did the trick.
CHINESE SPINDLE 2.2KW Ed Williams Open Source CNC Machine Designs 65 04-26-2012 01:01 PM
Chinese Spindle Experiences analogman DIY-CNC Router Table Machines 27 12-02-2009 05:37 AM
Chinese 2.2Kw spindle startup ccw Ed Williams DIY-CNC Router Table Machines 1 11-26-2009 10:10 AM
2.2 KW Chinese Spindle ? runout Ed Williams DIY-CNC Router Table Machines 4 09-23-2009 11:52 AM
Chinese Spindle after install Bugsy36 DIY-CNC Router Table Machines 23 08-08-2009 01:52 AM
