Old 12-04-2009, 09:35 PM
eloid is on a distinguished road
rack and rack & pinion with off the self planetary gearbox
Has anyone see and designs with r/p with off the shelf planetary gearbox
Try to get some ideas for tensioning the spur gear into the track with a planetary gearbox?
Old 12-04-2009, 10:24 PM
Al_The_Man's Avatar
Have you seen the post about the Rosta tensioner I used?
http://cnczone.com/forums/showthread...ighlight=rosta
http://www.lovejoy-inc.com/uploadedF...nerDevices.pdf
Old 12-05-2009, 08:56 PM
which picture had the rosta tensioner
Im planing on using a gear box planatery gearbox direct drive to the rack and pinion, dont see how the tension to maintaned on that rack? please explain.
Old 12-05-2009, 10:12 PM
Al_The_Man's Avatar
In the forum link, post #13 you can see the Rosta component I adapted on the R.H. side.
All of the pictures shown use the same device.
The Rosta parts used are DR-A27X100 BR27 & WS18-27.
These are tensioned by a twisting action and the centre axis can be pre-tensioned to ensure positive engagement, the assembly basically hinges on the Rosta device, these use high tensile rubber as the tension medium.
A picture of the cross section is shown at the top of every page in the Rosta pamphlet PDF.
Old 12-06-2009, 08:54 AM
Al_The_Man's Avatar
I should have added I held the centre post locked and the motor drive plate was attached to the outer part of the Rosta and allowed to pivot around the locked pin, under tension.
New Machine Build- Rack & Pinion captainkirk DIY-CNC Router Table Machines 2 06-27-2008 01:49 PM
Rack and Pinion Locster13 Linear and Rotary Motion 2 02-24-2006 09:07 AM
rack and pinion senor J. Linear and Rotary Motion 7 11-17-2005 04:21 PM
Rack and Pinion Hillman Linear and Rotary Motion 1 08-09-2005 04:14 PM
calculatiing pinion size for rack and pinion setup Apples DIY-CNC Router Table Machines 3 05-18-2004 09:36 PM
