Hi all, long time lurker. I'm in the process of designing a router and I believe I'll be using one of the water cooled Chinese spindles, either ER16, or ER20. Anyways, right now I have a cnc'd Taig (ER16 spindle) and was wondering if anyone has any ideas for tool changes and maintaining an accurate Z. Right now, I drop out the tool and reset the z-height which requires me to break up operations in to separate programs so I can reset everything between runs. Not exactly quick... I was thinking about creating an insulated, opto-isolated tool height probe similar to how the Datron mills are setup. Is this even possible while in a program? Judging by Hoss's tool-changer I'd guess that Mach3 can run programmed functions from gcode? Anyone have any idea if this is possible under EMC2? Thanks, -K |
| I was thinking just a small aluminum ring with allen key as a depth stop on the tool. Think it would imbalance it? Pretty much like these: http://www.woodshopbits.com/depth-co...ets-p-223.html And these small mills have pressed on plastic ones: http://www.thinktink.com/stack/volum...ting_rings.htm |
| I thought about collars, but the z height would end up becoming a function of the torque applied to the collet nut, I believe. Assuming that though, it would probably be reasonably repeatable as long as you put about the same force on the collet nut each time. I actually have a few collars sitting around, I'll try one tonight and see how accurate it is, it may still be a good option for my Taig assuming larger bits and slower rpms. I'd be a bit scared running those at 8-24k though. |
http://www.toolprice.com/c=l4cicoL0x...ch_Pounds.html Maybe just use solid collers (no set screws) and put them on with Loctite 609 retaining compound, you will need a torch if you want to get them off. |
| Best Collets | fentoneng | Toolgrinding & Toolgrinding Machines | 4 | 05-21-2009 11:03 AM |
| How repeatable is homing? | 1ctoolfool | Haas Mills | 9 | 03-10-2007 04:01 PM |
| collets | larry53 | Forum Questions or Problems | 1 | 10-05-2006 12:29 AM |
| Collets? how and why? | ZipSnipe | Benchtop Machines | 22 | 05-29-2006 08:31 PM |
| 5c collets? why? | ZipSnipe | General Metal Working Machines | 5 | 05-03-2006 08:52 PM |
