Old 11-30-2009, 01:23 PM
Schweinhund227's Avatar
Schweinhund227 is on a distinguished road
Cool Electrocraft PMDC servo ID ? Plz !
Hello all !
I need help !
I put my hands on a Used but in good condition Electrocraft PMDC servo motor from Al the Man ... well Now I want to power it up !
I have eyeballed this product ! from KB ! and was wondering if it could do the trick ??
Here is my Servo ID Plate !
it very plain !!! and any help Id this motor would be welcome...
as I need to find the HP this baby can deliver !
it comes with a Tach ! so I guess this will feed Speed feedback to the speed controler ? I'm new to this ! but I'm willing to play !!!
I found an Info sheet from Electrocraft Legacy Catalogue and was wondering if it could be the one for my Motor ? it's for a G700 series
Let me know !!!
Norm
out !
Old 11-30-2009, 01:54 PM
jalessi's Avatar
jalessi is on a distinguished road
Thumbs up
Norm,
Why not ask Al? He knows these like the back of his hand.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 11-30-2009, 02:10 PM
Al_The_Man's Avatar
I think I mentioned this has a terminal voltage of around 60vdc, IIRC.
I found this out by empirical test.
The KB should run it OK, but you will have to restrict it from max output, put a resistor in series with the pot or method used to control the speed in order it does not over speed on full 90vdc, I would not run it over 2500~3000 rpm to be on the safe side.
Unfortunately I believe the plate info is OEM part numbers which makes it difficult to pin down exact specs.
Old 11-30-2009, 08:20 PM
rgkerber is on a distinguished road
I am trying to get a print for you for this motor. I think Al is right that this motor is designed to run at only 60VDC. It will run with a 90VDC drive but it will eventually pit the commutator on the armature.
I'll let you know what I come up with.
Email me with any questions
Rob Kerber
VP/GM Motion
ElectroCraft
rkerber@electrocraft.com
Old 11-30-2009, 11:42 PM
Thanks Guys....
So... I am not too far off on my Driver selection...
I'll try to find one... near 70 or 80V and look for Big Resistors....
And another question ! Under Electrical Data in the Catalogue image...
under A and B what is the meaning of those letters ?
for each variant.... has 2 columns A + B ?
and the Tachometers... Do I have to do a Imperial Measurement on the output of the tach...or can I measure the impedance ! and Gestimate ?
and I'll try not to fry the motor...
Al would not be impress !
and thank you for looking for that Data Sheet for this Motor....
Take care ALL ~
Norm
OUT !
Old 12-01-2009, 09:02 AM
Al_The_Man's Avatar
The Tach output is a generated DC voltage proportional to rpm, usually indicated in v/1000rpm.
You can easily measure this at a given speed.
Don't put any resistors in series with the motor, the one I indicated would go in series on the high end of a control potentiometer for example.
Also there are quite a few A-M-C servo controllers on ebay that can be run in the velocity mode for spindles.
Old 12-01-2009, 01:17 PM
Thank you AL !
I see your point ! about the Tach ! and about the Resistor... on the Pot !
what about the Horse Power Resistor... ??? on that KB Drive ?
They come in all Flavours...
the A M C drivers... well !!! are out of my League ! 300$ ouchie !
I don't need anything fancy !!! but controlabe via Mach 3 !!! with analogue ref. voltage from the Tach as a Spindle Speed Control Accel and Decel !
are Breaking Resistors required ? or a controlled Decel time good enough ?
Sorry for the Many questions but I don't want to Burn anything...
ie. when the Servo is Free spining... and feeding EMF back into my board !
so much to learn so little time !!!
Norm
out !
Old 12-01-2009, 01:34 PM
Al_The_Man's Avatar
I would go with a 1/2hp value to begin with. The worst case scenario is you would go into current limiting earlier, but I don't think that will happen.
Need Help!- Electrocraft BRU 105 Servo drive Schematic lekridge Want To Buy...Need help! 8 03-27-2009 03:14 AM
Electrocraft servo - How do they work? Chris64 Servo Motors and Drives 6 10-05-2006 10:12 AM
Electrocraft Servo 0660-12-031 bemfarmer Servo Motors and Drives 0 09-03-2006 05:11 PM
Looking for a source for PMDC servo motors bgolash Servo Motors and Drives 4 01-31-2006 03:26 PM
