Old 03-26-2005, 08:46 PM
Ursine is on a distinguished road
Black Gas Pipe size
Hi All,
I'm new to all this, so excuse me if this has been covered already. I was at Lowes today measuring gas pipe for the rails. I quickly realized the 1" pipe doesn't mean O.D. This explains it. Surprised me it was so far off. Might help someone else.
http://www.ajfittings.com/performance_charts.htm
Dave
Old 01-06-2011, 06:55 PM
naic98 is on a distinguished road
Pipe Versus Tubing
Pipes are measured by the Inside Diameter I.D., versus tubing which is measured by the Outside Diameter O.D. Pipes are used to move fluids, it's important that all pipes of the same size have the same inside dimension (turbulence and lots of other problems).
Tubing is used for construction, keeping O.D. constant is important!
Gas Pipe Alternative? JavaDog DIY-CNC Router Table Machines 8 01-07-2011 10:24 AM
Need gas pipe mount jackasscowboy DIY-CNC Router Table Machines 1 06-13-2005 03:36 PM
gas pipe & linear bearing dimensions relationship zoltan Linear and Rotary Motion 6 06-13-2005 03:12 PM
Black pipe questions ljoe1969 DIY-CNC Router Table Machines 20 02-21-2004 03:24 PM
Support For Gas Pipe Rails Mr.Chips DIY-CNC Router Table Machines 26 02-17-2004 08:12 AM
