Old 11-27-2009, 05:01 PM
FXC FXC is offline
FXC is on a distinguished road
Exclamation Anyone who wants to build a machine (or can recommend something), LQQK!
Hello everyone!
Due to practical and not necessarily economical reasons, having my own rig seems the logical way to go. This machine's sole purpose in life will be to cut the plastic parts I described in this thread and, except for minor changes, not much else.
If anyone here would like to either contract build something suitable or recommend an existing turnkey solution, I'd like to hear from you!
By the way, I didn't make a final decision following the aforementioned thread and I'll make this last ditch effort to find someone local: if you're in the Chicago, IL area, you'd have a HUGE advantage so check it out!
Thank you,
Old 11-27-2009, 06:39 PM
leggazoid is on a distinguished road
Here is a $1200 suggestion that will take about a 2-week delivery. I think with a good spindle it would do ok on your plastic parts. I make no guarantees, you were lacking in detail about the precision you desire.
FireBall V90 CNC Router FireBall V90 CNC Router
- Motor/Driver Kit 3-Axis ProboStep Motor/Driver Kit (Best)
- Breakout Board PBX-RF
- Ready-to-run Large Enclosure
- Kit Power Supply Upgrade 32VDC Linear Components Kit
- CNC Control Software EMC2 Disc
FireBall V90 $1,159.94
What is your primary concern? lead time for delivery, precision, space or price?
Anyone else like to chime in with recommendations?
Old 11-27-2009, 07:31 PM
Trucks is on a distinguished road
Sent you a message! I am in the Milwaukee, WI area, I look forward to hearing back from you.
Need A Quote- CNC Machine Build CyborgCNC Employment Opportunity 6 08-04-2009 03:28 PM
Recommend CNC machine for Coin Dies ardorlan Virtual Sculptor VS3D / VScad3 Software 3 10-19-2008 01:59 PM
Would you recommend building a CNC milling machine? alexccmeister General Metal Working Machines 11 07-24-2008 09:28 AM
Please Recommend a Home welding machine ThomasAlva Welding, Brazing, Soldering, Sealing 8 08-23-2007 01:34 AM
Use the second machine to build the first! Madclicker CNC Wood Router Project Log 160 06-26-2007 11:29 PM
