Old 11-25-2009, 08:13 AM
Droider is on a distinguished road
Mach 3, Soft Limits
Hello,
So my new problem is setting up the soft limits. I have my homing switches installed, and they work great. But what I need now is to get my soft limit switches working. What is happening at the moment, when I try and turn on my soft limits it gives me an error saying "Cannot activate when out of soft limits." But my machine is at its zero's when I get that. Has anyone had this problem? Does anyone know how to fix it?
Thank you.
Old 11-25-2009, 08:19 AM
br1 br1 is offline
br1 is on a distinguished road
First in Motor Home / Soft Limits configuration set The slow zone. Then Jog a distance away (this has to be at least the distance of your slow zone) from where ever you set Zero, then activate the soft limits button, In Motor Home / Soft Limits configuration I have .5 (1/2 inch if using inches) in the Slow Zone. Works for me.
Old 11-25-2009, 10:14 AM
ger21's Avatar
Make sure you don't have the max and min set backwards.
Old 11-25-2009, 04:18 PM
Haha yeah I was doing both of those wrong. I had the max at a higher value than the min. I figured the max movement i wanted was -5, and the min to be my 0. I switched it around and it works. Ready to run a program tomorrow I think!
Need Help!- Okuma soft limits Carlton Jenkins Okuma 6 02-14-2012 06:58 AM
Backing off home switches in Mach 3 with soft limits?? Gerry?? jbluetooth DIY-CNC Router Table Machines 5 09-29-2009 03:47 PM
Problem- soft limits zimba43 Mach Mill 2 04-01-2008 04:18 PM
Mach turn settup soft limits and tip numbers Green0 Mach Lathe 1 03-31-2008 03:35 PM
Question about Soft Limits??? Dennis Fletcher Mach Software (ArtSoft software) 3 07-31-2005 01:07 PM
