Old 11-24-2009, 04:35 AM
frostyshoal is on a distinguished road
dust colector question and help
I have a 500 CFM dust collector I got from Menards and I'm wondering if the filter bag is just not a good quality or if this is normal but when it is running and sucking up dust if you touch or poke the bag very fine dust will go up into the air im not sure if it can filter small enough or if that small amount is normal. Should I buy a new bag or something, any help?
Old 11-24-2009, 05:35 PM
justCNCit is on a distinguished road
all i know is if your working with MDF the dust is so fine the only filters that actually work are the cyclone types. That stuff will stay ambient floating in the air for days and toxic.
Old 11-24-2009, 05:40 PM
ger21's Avatar
Cheaper dust collectors can let a lot of fine dust through them. The best bags can filter down to 1 micron. By letting the dust build up in the bag, it'll actually start to filter more fine dust. You may be able to by a better bag, but they are not cheap. You may also be able to modify the collector to use a cartridge filter, but those are even more expensive.
http://www.wynnenv.com/35A_series_cartridge_kit.htm
Tags
dust collector bag
Dust Catcher brooklynsual CNCzone Club House 0 12-02-2008 12:06 PM
Need Help!- Need a dust collector Dark-Angel Composites, Exotic Metals etc 1 11-16-2008 07:35 AM
Dust collector SPEEDRE DIY-CNC Router Table Machines 4 06-30-2007 08:45 AM
Dust Extraction sploo WoodWorking 12 04-06-2007 01:57 PM
Dust/Chip Control...CNC Dust Enclosures Too_Many_Tools DIY-CNC Router Table Machines 17 07-29-2006 01:44 PM
