Old 03-24-2005, 02:22 PM
Ursine is on a distinguished road
Z axis Flanged Bearings.
Due to the limited motion of the Z axis, I was thinking UHMW flanged bearings. Seems the alum angle and skate bearings would be overkill. I'd love to hear from anyone having experience with them.
Thanks,
Dave
Old 03-24-2005, 04:27 PM
WP1 WP1 is offline
WP1 is on a distinguished road
Bad idea.
Travel may be limited on the Z, but in many cases the Z axis gets a very heavy workout. Engraving text or photos, and PCB drilling are two good examples.
Pete C.
Old 03-24-2005, 06:14 PM
Ninjak2k is on a distinguished road
Victorbl is using these for his whole machine. http://www.cnczone.com/forums/showthread.php?t=7614 He started with oilite bushings if I remember right and then switched to those and they were much better.
Why do you feel they would be a bad idea? I don't have the materials and dynamics background to do any calculations about it and any insight is appreciated.
~Dan
Old 03-24-2005, 09:41 PM
WP1 WP1 is offline
It's not so much that UHMW bushings can't work, it more that the assumption that the Z axis does less work than the X and Y is incorrect.
Many operations such as the engraving and PCB drilling noted put very high demands on the Z axis. In fact since the Z generally has a much smaller travel than the X and Y any given point in the Z slide is likely to see higher wear than a point on the X or Y axis.
Pete C.
Ballscrew Basics Swede Linear and Rotary Motion 101 04-16-2012 08:09 PM
4020 4th axis problems little bubba Fadal 3 06-13-2005 09:08 PM
No Encoder Counts On X Axis. Y=OK murphy625 CamSoft Products 5 03-08-2005 08:20 PM
2 axis to 3 axis conversion drembedded Bridgeport and Hardinge Mills 10 10-27-2004 11:32 AM
2.5-Axis vs 3-Axis JamesBond General Metal Working Machines 6 07-26-2003 07:09 PM
