Old 11-19-2009, 11:04 AM
mhiggins is on a distinguished road
Joe's 2006 Upgrade
I have been working on a new gantry for my 2006 which incorporates design elements from Joe's 4x4 as well as mods inspired by other DIY machines, commercial units and some of my own ideas. I will try to give credit to those whose concepts inspired my design but sometimes I forget where I found them. I'll do my best since I don't want to take credit for anyone's work.
I know my existing machine doesn't look exactly like the traditional Joe's 2006. If you would like to know why, here is a link to my original machine build.
http://www.cnczone.com/forums/showth...ghtly+modified
Mike
If you can't overbuild it, what's the point?
Old 11-19-2009, 11:08 AM
Part 2
Mike
Old 11-19-2009, 11:11 AM
Fourth axis part 1
Some info on the 4th axis build.
Mike
Old 11-19-2009, 11:13 AM
Fourth axis part 2
More an the 4th axis.
Mike
Old 11-20-2009, 06:33 AM
*Registered User*
DayneInfo is on a distinguished road
HURRY...I want to see more
Old 11-20-2009, 09:11 AM
calgrdnr is on a distinguished road
Thanks Mike , I have been think about modding my z and y also. I will be watching with great interest. also would like indexer
Kent
Old 11-20-2009, 07:57 PM
Cable carrier
Here is a video showing my cable carrier. I modified drawings I found on this thread to create the toolpath.
http://www.cnczone.com/forums/showth...=cable+carrier
Mike
Old 11-20-2009, 08:14 PM
Carriage
I found the inspiration for the carriage on this thread.
http://www.cnczone.com/forums/showth...uter+enclosure
I changed the design by leaving two inches between the 1030 extrusions to make room for the leadscrew. The plates on top and bottom were made with a hacksaw and a file out of some scrap machine parts I had on hand and are 3/8" thick.
I used 1/4" plate on the front and back. Two pieces on the front to allow for the leadnut to pass between. Two pieces on the back to allow for additional adjustment between the upper and lower v-groove bearings. The bolts that mount the bearings pass through the plates and thread into nuts in the extrusion.
EDIT: I almost forgot to thank Joe for his 4x4 design which is the inspiration for the gantry and v-groove bearings. The last pic sort of tells it all.
ID:	93672   Click image for larger version
ID:	93673   Click image for larger version
ID:	93674   Click image for larger version
Mike
Last edited by mhiggins; 11-20-2009 at 10:10 PM. Reason: Giving Joe his well deserved credit.
Old 11-20-2009, 08:33 PM
More carriage and Z-axis
I used 3/4" aluminum plate for the Z-axis. The leadnut is mounted to another piece I sawed out of scrap extrusion and bolted to the back of the 3/4" plate. The center pic shows how I used a bushing to line up and mark the bracket with a transfer punch. The bushing was filed down on the drill press to fit the hole in the upper bracket of the carriage.
In the first pic you can see there is a bearing block on the top and bottom of the upper plate. The two bearings are loaded against each other and there is no support for the leadscrew at the bottom it just free floats. I used a dumpster threaded clamp on the top and a plain steel clamp on the bottom.
ID:	93677   Click image for larger version
ID:	93680   Click image for larger version
Mike
Old 11-20-2009, 08:46 PM
lumberjack_jeff is on a distinguished road
Very nice cable chain. What dimensions did you use?
  #11   Ban this user!
Old 11-20-2009, 08:48 PM
FandZ's Avatar
FandZ is on a distinguished road
I like it all. Nice work! I'm going to have to make some of that energy chain. I recently enclosed my wires into a wire shield like you showed in your 1st video. I just couldn't figure out why I couldn't make it bend in the air like yours did...lol I feel like an idiot now.
  #12   Ban this user!
Old 11-20-2009, 08:52 PM
Carriage lead nut bracket
The first pic shows the bracket for the leadnut and the second shows a gusset that I added just for the heck of it. I'm sure it would have been plenty stong without it.
In the last pic you can't actually see the leadnut but you can see theends of the machine screws that hold it on. You will also notice that I drilled a 5/16" hole just below the leadscrew for a 1/4" rod to pass through. I made HDPE support followers for the leadscrew. I threaded the ends of some harware store steel rod to screw into the followers and used jamb nuts to keep them tight and indexed. You can see the jamb nut in the last pic.
All I had was 3/4" HDPE so I cut a 1" wide piece for the bottom and cut a 1/4" deep tenon to ride in the slot on the extrusion. I used a 1/2" ball mill to cut the groove in the top and bolted the two pieces together with machine screws. The followers are captured between the extrusion and the leadscrew. The leadnut bracket will hit one of the followers and drag the whole assembly with it allowing the other follower to support the leadscrew. The followers are short enough that they don't reduce the axis travel.
EDIT: I added a pic that shows the follower a little better.
ID:	93682   Click image for larger version
ID:	93683   Click image for larger version
ID:	93684   Click image for larger version
Mike
Tags
fourth axis, gantry, joe, router, upgrade
Joe's CNC Model 2006 joecnc2006 Joes CNC Model 2006 1730 11-14-2011 07:55 AM
New Machine Build- Going to Try Again...With a Joe's 2006 emtffkev Joes CNC Model 2006 3 09-27-2009 02:42 PM
Difference between Joe's 2006 R1 and R2 ? newsense2004 Joes CNC Model 2006 2 08-10-2009 10:55 PM
Joe's 2006 in Albuquerque TCGliderguy Joes CNC Model 2006 119 03-23-2009 12:29 PM
Joe's 2006 in OH fade2black Joes CNC Model 2006 44 07-18-2007 08:46 PM
