Old 11-19-2009, 10:03 AM
Droider is on a distinguished road
Motors Wont Spin?
Okay so, to explain where I am. I bought a 3 axis gecko 540 package from kelinginc.net. Came with everything. I used this wiring diagram http://www.kelinginc.net/G540WD.pdf. Wired everything together (I beleive correctly). When I was trying to tune them on Mach 3 apparently they are suppost to spin as I am adjusting them, and they did not.
So whats happening is when I plug the power supply in the motors pulse and tighten up, and cannot be spun freely anymore. G540 lights up green with power with charge pump off, and Estop not pressed. I had the motors on trying to get Mach 3 to spin them for about 30 minutes, and they got fairly warm (Maybe this is normal?). I was following the mach 3 tutorial supplied by kelinginc on their website, and I think i set mach 3 up corretly as well.
So I am not really sure where I went wrong. Any ideas?
Old 11-19-2009, 10:12 AM
jalessi's Avatar
jalessi is on a distinguished road
Question
Droider,
Did you copy the G540B.xml file to your C:\Mach3 directory?
The motors are working correctly, they should lock up when the G540 is powered up.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 11-19-2009, 10:13 AM
ger21's Avatar
Are you using the up and down arrows in the motor tuning screen?
Old 11-19-2009, 10:17 AM
Do i just unzip that right into the main c/Mach3 folder?
Old 11-19-2009, 10:19 AM
jalessi's Avatar
Post
Yes unzip the file to: C:\mach3
Old 11-19-2009, 10:25 AM
THEY SPIN!
Butt... The Y motor, doesnt spin as fast as the others, and when I make it spin forward it messes up badly. Spins fine for 3-4 seconds then sounds like its grinding and spins backwards then forwards then backwards then forwards etc really fast. Bad wiring there?
Old 11-19-2009, 10:30 AM
Oh, Nevermind I got it fixed. I was following 2 guides for setting up mach 3, and one set to click the "sherline 1/2 pulse mode." When I unclicked that it works fine.
Old 11-19-2009, 10:32 AM
jalessi's Avatar
Post
You can try switching the X motor to the Y axis on the G540 and see if the problem goes away.
Make sure you turn the power off before switching the motor.
Jeff...
Old 11-19-2009, 10:33 AM
jalessi's Avatar
Thumbs up
Awesome.
Old 11-19-2009, 12:33 PM
Having a problem with my E-Stop. When I press it the motors stop, and the G540 goes into fault. But mach 3 doesnt notice and continues to make the move.
I have the E-Stop set in the input signals to..
Enabled On. Port # 1. Pin #13. Active Low On. Emulated off.
I think the problem has to do with the active low being on. But I cannot seem to reset mach 3 any other way.
  #11   Ban this user!
Old 11-19-2009, 12:49 PM
jalessi's Avatar
Post
The EStop should be on pin 15
Mach III Motors wont turn backward jjenks General CAM Discussion 5 11-02-2009 08:01 AM
Newbie- Motors don't spin at high spped! kooroshi60 Mach Mill 3 12-31-2008 09:57 AM
stepper motors only spin in one direction nicanor76 DIY-CNC Router Table Machines 3 08-04-2008 01:28 AM
Motors spin only ~60rpm? DennisCNC Mach Software (ArtSoft software) 3 11-26-2005 07:52 PM
Motors wont turn moto21 Mach Software (ArtSoft software) 15 09-22-2005 10:13 AM
