Old 11-18-2009, 08:28 PM
eloid is on a distinguished road
hotwire foam cutting software
looking for a software to generate gcode for hotwire foam cutter
mainly for 2d profile extrusions etc
Old 11-19-2009, 09:36 AM
lovebugjunkie's Avatar
Gold Member
lovebugjunkie is on a distinguished road
http://www.foamwork.net/download.htm
http://gm.cnc.free.fr/en/index.html
http://www.cenece.com/eng/index.htm
http://www.profili2.com/eng/default.htm
Old 11-20-2009, 08:09 PM
demo, or free software
hi lovebugjunkie,
thank for the reply, I have too look at the site closer, any of theses
packages free ? or have limited trial run?
looking to play before I pay..... then settle down with a package...
I need to cut 2d foam contours ie mouldings, for prototyping
on 3 axis cnc...
Need Help!- EPS foam deffective? Hotwire issues.... Help! stevecash83 CNC Wire Foam Cutter Machines 2 06-24-2009 02:14 PM
Hotwire Foam Cutter paprjam Casting Metals 0 03-23-2009 11:45 AM
Need used hotwire CNC for EPS foam dizzywizzy Want To Buy...Need help! 1 02-22-2009 07:43 PM
Foam Cutting Software Mcyoda CNC Wire Foam Cutter Machines 0 08-22-2008 10:42 PM
foam cutting software, and motors ? help max_imum2000 CNC Wire Foam Cutter Machines 8 11-18-2006 06:11 PM
