Old 11-17-2009, 06:40 PM
zeeway is on a distinguished road
AB Nut on Z axis?
It seems to me that gravity may provide the anti-backlash capability to a simple feed nut on the Z axis. Here's my thinking...when the router moves up or down, gravity is always pushing down, so the nut should always be riding the "top" side of the threads. Even when the router is drilling down and the material is pushing back, the router turns at such a high rpm that again the router doesn't see the backlash for more than a flash.
So, I am thinking that on the Z axis, all I need is a simple delrin feed nut without the anti-backlash jazz. Is this correct, or am I missing something?
Old 11-17-2009, 06:56 PM
ger21's Avatar
If you use a downcut spiral bit, it'll climb up if there's backlash. And it can take much more force than you think to plunge into material.
Old 11-17-2009, 07:08 PM
Hmmm, I guess that's a good reason. Okay, anti-backlash on Z also. Thanks for the info.
the Difference of 2-Axis and 3-Axis of Vertical Mill Machine begacon Knee Vertical Mills 6 07-30-2009 06:31 AM
Compare Catia and MCX2 for multi axis lathe/4 axis mill bob1112 General CAM Discussion 0 10-10-2008 07:15 PM
How can I coupling a stepper motor axis directly to other axis? meknik2001 Stepper Motors and Drives 4 05-08-2008 01:54 PM
One axis (z-axis?) computer controlled testing device TsThorsell Stepper Motors and Drives 3 02-07-2008 12:38 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
