Old 11-15-2009, 09:15 PM
corwes is on a distinguished road
Long X axis
I have been collecting parts for a CNC router over a couple of years and
finally am starting to build. I was going to build an 8 x 4 machine with four axis
and dual spindles ( separate drilling spindle ). My latest acquisition is a pair
of 14 feet long NSK linear rails that came out of an old injection molding robot.
I feel that it would be such a waste to cut them shorter. I can see a use for
a long X axis, with the 4 axis I would be able to turn 12 feet long columns.
What other uses would there be for such a long machine?
I am looking for excuses to justify the extra space I am going to sacrifice in my
workshop.
Old 11-15-2009, 09:25 PM
ger21's Avatar
You can cut 12ft sheets of board.
Old 11-15-2009, 09:30 PM
FandZ's Avatar
FandZ is on a distinguished road
Sounds like you could make two machines in one. You could have two gantries facing each other. Double the fun and twice the production. You could cnc a canoe...
Maybe use one side as a cnc lath somehow? It should be interesting to see what others suggest.
Old 11-16-2009, 10:30 AM
LazyMan is on a distinguished road
Personally, I would not build a significantly larger machine than planned or needed (especially if it is large already) just because it is a shame to cut down long rails. The extra costs and complications associated in building XXL machine and keeping it as rigid can really increase quite a bit. However, if your only concern is space than why not?
Dual Drive on Long Axis? rweatherly JGRO Router Table Design 17 11-30-2008 01:21 AM
4x8 router w/Gantry on the long axis sds357 DIY-CNC Router Table Machines 1 11-10-2008 02:57 PM
Long Z axis problem Karlf DIY-CNC Router Table Machines 30 04-01-2008 05:02 PM
Long X-Axis w/o leadscrews Jerry In Maine Open Source CNC Machine Designs 3 07-09-2007 04:13 PM
Long Z axis machines ynneb DIY-CNC Router Table Machines 2 02-01-2007 06:58 PM
