Old 11-09-2009, 04:25 PM
ilya is on a distinguished road
Low-speed (rpm) spindle wanted!
I'm looking for a milling spindle that can work in the range of up to 3000-5000 RPM. I've got a high-speed spindle installed on my DIY 8020 aluminum machine, and I find it somewhat limiing, for ex. I can't do any facemilling and I can't use any bits that are larger than, say, 1/4" (on metals, I mean).
I've seen some people mention using servos as a spindle motors. Has anybody done that? How's this work?
Another thing I'm considering is getting the head assembly from littlemachineshop or Sherline (P/N 6513, 6514). However, Mini Mill assy seems to have a dovetail (which I don't actually need) ,and Sherline doesn't give any dimensions of its headstock.
Any ideas?
My DIY CNC router plans at www.8020CNC.com
Old 11-09-2009, 10:12 PM
jsheerin's Avatar
jsheerin is on a distinguished road
http://littlemachineshop.com/product...ory=-269978449
Why not get this one and add a pulley, motor and controller? I'm not sure if you can do that though - I don't know what the other end of the spindle looks like.
Old 11-10-2009, 02:50 PM
jsheerin,
That's exactly the problem I'm facing right now! I saw that block but I can't find enough details about it to make any assumptions...
Old 11-10-2009, 03:03 PM
jsheerin's Avatar
I think it would be possible - see pic's here:
http://www.cnczone.com/forums/showpo...8&postcount=43
http://www.cnczone.com/forums/showpo...3&postcount=57
Info here:
http://www.cnczone.com/forums/showpo...5&postcount=82
Or maybe email the littlemachineshop people and ask them about it. Maybe they could take another picture for you of the other end. Alternatively, look at www.grizzly.com. They have parts manuals for some of their machines with exploded views. You can also order replacement parts.
Old 11-10-2009, 03:07 PM
jsheerin's Avatar
Or better yet, look here:
http://www.fignoggle.com/workshop/ar...version-part-1
Old 11-10-2009, 03:16 PM
Yeah, this looks like a it can be built relatively easy.
Do you know of any source for not-very-heavy DC motors to run the spindle?
Old 11-10-2009, 03:35 PM
jsheerin's Avatar
Sorry, I don't know many sources in Russia... Personally I would run a 3ph motor with a VFD, but that's because I have piles of small VFD's sitting around and low power 3ph motors are fairly cheap. They're not very light though... The usual suspect for things like this are surplus treadmill motors. I have one that's rated for 2 or 3HP and it's a bit lighter and smaller than the 1/2HP 3ph motor I have on my lathe. I got it from tearing apart a dead treadmill.
Old 11-13-2009, 01:29 PM
jsheerin's Avatar
I forgot we have one of these small bench mills at work. I was looking at it today and it looks like it should not be a problem to modify. So I bought one of the heads from Little Machine Shop to build a drill head for my router. I'll post some pics when it shows up.
Old 11-13-2009, 07:51 PM
Jason3's Avatar
Jason3 is on a distinguished road
Hi there,
This might be a bit late to be much use, but here's a spindle made up by mounting a servo to a live tool off a big CNC lathe. It was actually intended to be switched between the lathe and a mill, but hasn't made it to the mill yet The speed range is up to 4500 rpm, and it just uses the Mach3 step/direction spindle output for control. A nice thing about using the servo might be the ability to use the index pulse from the encoder for threading in Mach3 Turn.
There's a little more about it here - http://zealcnc.wordjot.co.nz/posts/the-micro-lathe/
Best regards,
Jason
ID:	93330   Click image for larger version
Old 11-15-2009, 11:05 AM
jsheerin,
If you can post pics that would be of a great help to me!
Jason,
Is the motor directly coupled to the tool holder? Have you milled anything with it yet?
Meanwhile I'm researching a possiblity to control my spindle motor (it's a universal collector motor) with something like a KBIC. Like this one:
http://www.galco.com/scripts/cgiip.e...%20ELECTRONICS
Does anybody have any experience with those?
  #11   Ban this user!
Old 11-15-2009, 03:21 PM
Jason3's Avatar
Ilya, yes - it's coupled directly to the back of the tool holder. It was originally a new right angle drive type that was rejected due to a flaw in the drive gear. I removed the gears and replaced the bearing retainer nut with one I made with spider type coupling fingers. I haven't milled anything yet, but I have used it for turning - it works pretty well. It could do with a bit more power for parting stainless steel, but a bigger servo should fix that.
Best regards,
Jason
  #12   Ban this user!
Old 11-21-2009, 01:08 PM
jsheerin's Avatar
As promised, here are some pics of the mini mill head. I got the R8 taper spindle and a drill chuck and set of collets with mine. I plan on using it as a drilling and milling head. I'm going to try using a DC treadmill motor to drive it with a timing belt. The head by itself weighs 5.48kg, and the drill chuck weighs 1.04kg. I haven't been able to remove the nut from the rear of the shaft so far, but can post more pics when I do. If anyone has tips for how to get that off without scratching up the shaft, I'm all ears.
ID:	93716   Click image for larger version
ID:	93717   Click image for larger version
ID:	93718   Click image for larger version
Wanted Lathe, oil field and hollow spindle nemco Want To Buy...Need help! 0 09-14-2008 10:33 AM
Spindle Speed mikemill General CNC (Mill and Lathe) Control Software (NC) 0 01-04-2008 10:09 AM
Spindle Speed teenrocketnerd DIY-CNC Router Table Machines 1 06-20-2007 05:59 PM
spindle speed Mike Boarman Machines running Mach Software 0 11-27-2006 09:37 PM
BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? peter.blais Bridgeport and Hardinge Mills 9 08-08-2006 03:29 AM
