| I have used this principle, Breco Belts sell the belting and hardware for this method. Al.
| I wanted to use belts and eventually decided to just go with rack and pinion because it was more cost effective in the end. If you do go with belts take a look at http://www.cnczone.com/forums/showthread.php?t=59570 |
A 1" pulley will give you 3.14" of travel, so I think you'd need 9:1 gearing to get 1" of travel for 3 stepper rev's. And with larger belts, you may need larger than 1" pulleys.
| Gerry I have a couple of problems in this design. Here I go. I'm using a 20mm jack shaft on x to drive pulleys on each side. So the 20mm limits me on the size of pulley I can use. I'm using at5 25mm belts. I have on the servo 14t and jack shaft 42t. This is 3 to 1. Now the smallest pulley I can go is 28t because of 20mm jack shaft. This puts me at 46.6666666mm per motor rev. That is putting me around 1.8372 inches per rev. I know on my other machine my servos at 1 inch per rev will snap a bit like it was even there on a screw up. So I'm hoping that I will still have enough torque on this new setup. I using a 150w YAG laser so no drag. But I want to add a spindle for pockets. What do you think? Ed |
| Timing belt and pulleys | samakthachai | Laser Engraving & Cutting Machines | 8 | 10-24-2007 11:31 PM |
| Ball screw or Timing belt | skazic | Linear and Rotary Motion | 7 | 06-27-2007 05:14 PM |
| Ball screw, Timing belt or Rack and pinion | abomination | Linear and Rotary Motion | 10 | 04-30-2007 10:14 PM |
| HTD timing belt pulley | R.thayer | General CAM Discussion | 1 | 02-03-2007 12:42 AM |
| Should you put grease on a timing belt? | ynneb | DIY-CNC Router Table Machines | 5 | 04-22-2004 08:54 AM |
